That's one way to do the job,but I don't see any advantage beyond reducing the draught of the boat.Having a hull section between the major part of the boat and the rudder won't make it easy to access the notch where rope or seaweed will be lodged.I believe a better solution is that which is commonly used in the IMOCA class.The diamond shaped frame is pivoted and very well located and there is good access to the underwater section.View attachment 195349
Me too. The rudder must be supported all the way to fully kicked up, otherwise the side loads will damage the hinges. The lifting stern and to a lesser extent Sol's will need very strong hinges if, eg a breaking wave hits them when they are kicked up and floatingI'm not so sure the 'kick-up transom' section on the trimaran would be any more prone to fouling or a hassle to clear than any other rudder, kick-up or not. The IMOCA rudder design actually looks very stout and functional. I bet there is more materials, time, and engineering (=$$) than most any other option discussed in this thread. What appeals to me from an engineering standpoint is any solution that gives decent lateral support to the rudder blade as it pivots back and up. Wide bearing support and triangles make sense.
I quite like the rudder setup in post #37 and when down it shares with the IMOCA the use of a notched hull for lateral bracing.What might not be particularly clear is that the IMOCA also has about 350mm of hull beyond the actual transom to provide a step in the style of a sugar scoop.What I'm not so thrilled to see on the trimaran setup is the central moulding mounted a bit too high to provide a seating for the pivot,while leaving a lateral step in the immersed portion and a gap for water to move through.I'm guessing that somebody didn't loft the arrangement and include enough length for the rudder stock,otherwise the rudder could have been made to more closely conform to the keel line of the hull,for greater efficiency.I hope nobody thinks I'm being too harsh,but the thread title includes the word critique and I hope we will all gain knowledge from absorbing the various contributions.I would speculate that a tubular stainless fabrication that approximates the IMOCA principles,and has a hull shaped section located in a matching cutout might not be a huge amount more expensive than the enclosed moulding on the trimaran.I also hope that anybody interested in rudder design who lives within travelling distance of New York made the trip to ponder the solutions the IMOCAs use for all sorts of systems over the last couple of weeks.
