DCockey
Participant
- Joined
- Oct 24, 2009
- Posts
- 5,309
- Reaction score
- 682
- Location
- Midcoast Maine
UK canal boats are designed for a very specific set of size limitations, and may not be good boats for some other bodies of waters. UK narrow boats are designed to fit through locks which limit beam to 7 feet. Wide boats are typically limited to 13 or 14 feet maximum beam depending on which canals the wide boat will be used on. Draft is limited to 3 feet and typical is 2 feet or less. There are also "air draft limitations", ie maximum height above the water due to low bridges and tunnels. UK canals are sheltered with some but not all being dug ditches. UK rivers which canal boats are typically used on are much smaller and more sheltered than the Hudson below Albany or the St. Lawrence. While narrow boats have crossed the English Channel on days with good weather it is generally not considered to be a good idea.
Size limitations for North American canal systems are much larger:
Erie Canal, Hudson Canal, etc: 328 feet long and 45 feet wide. The area available for vessels within a lock is 300 feet long, 43.5 feet wide.
Rideau Canal (Ontario, Canada): Locks are 41 metres/134 feet long by 10 metres/33 feet wide.
Trent Severn Waterway (Ontario, Canada): The smallest lock on the Trent-Severn is Port Severn (Lock #45). It measures 25.4m (84') long and 7.0m (23') wide.
St. Lawrence Seaway: Each lock is 233.5 metres long (766 feet), 24.4 metres wide (80 feet) and 9.1 metres deep (30 feet) over the sill.
