inflatable catamaran design (big size)
Discussion in 'Boat Design' started by gabdab, Jul 29, 2010.
  1. gabdab
    gabdab Junior Member
    Any 'big size' inflatable catamaran available or what are design characteristics to be considered in making one ?
  2. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    Not a cat, but get two of them and who knows?:)
    http://www.boatdesign.net/forums/boat-design/can-anyone-find-weirder-boat-22769-2.html
    Photos in link above.
  3. Petros
    Petros Senior Member
    I like the idea! Go get two of those inflatable kayak-canoe like things, make a fold-able frame that holds it all together, with a sail board or hobie cat sail, and you got a 2-person plus catamaran that will store in a closet! Should not cost too much to make either. You could get by with a single rudder and center board on your frame (keep it simple!).
    http://www.amazon.com/Sevylor-Inflatable-Fiji-Kayak-Travel/dp/B000K8PKRU
    once you get it all together, post pictures of it for us.
  4. keysdisease
    Likes: 43, Points: 28, Legacy Rep: 324
    keysdisease Senior Member
    Take a look here, up to 28ft but this company will make just about anything, and they do very nice work.
    http://www.nauticaintl.com/Boats/Catamaran/catamaran28.htm
    Steve
  5. gabdab
    That is what I was looking for ,sort of 'ducky' sailing catamarans but bigger.
  6. keysdisease
    Take a look here. This guy did an outstanding job of using 2 canoes as a sailing catamaran.
    http://www.boatdesign.net/forums/multihulls/crazy-canoe-cat-33874.html
    A very nicely engineered vessel that seems to have excellent sailing characteristics. Throughout the video it appears as if the vessel is sailing with the tiller lashed.
    Steve
  7. yipster
    yipster designer
    bigger you may think of banana tubes..
    order the bottom steps of but topmounts for the beams
  8. gabdab
    I admit banana tubes look quite ad hoc , but they are preatty expensive aren't they ?
    What puzzles me more is the solid structure and inflatable/structure joints.
  9. jonr
    jonr Senior Member
    Inflating or pressurizing a hull makes it stiffer without adding much weight. But it also tends to make the enclosed area unusable for other purposes.
