Hopefully an RC Sailboat in the future
Baldr
Junior Member
Joined
Aug 3, 2026
Posts
33
Reaction score
6
Location
Bergen, Norway
Sunday almost done,
Cut-outs made in Curves wokbench with "waterlines tool" and then cut and 3d-offsat in Part workbench. Part is then Meshed in Mesh workbench and unwrapped for flat 2d profile:
Instead of 3d-offsetting cutouts, one can extrude along curved plates' normals. Better results/seams.
But it's got no mast.
Can you show the whole boat please, with dimensions.
Yes. I know. I'm just puttering along. As I'm not a professional boat designer, this endeavor is also a dive into the CAD program and it's abilities and getting to know them. I do have some preliminary sail arrangement, but it's not worth showing yet.
This is the bounding box. Numbers in mm:
If you want meaningful feedback it is worth showing.
Yes, but I might also get some questions... I mostly show what I've got as soon as I have something new.
Something like this, maybe? It's a first draft and some calculations would have to be made.
What's the intended use? It looks like a beamier, slightly shorter version of a Marblehead given a very short rig and fin (keel on a full size boat). THE AMYA - American Model Yachting Association https://www.theamya.org/BoatClassDetail.asp?BCID=36 In some ways, it is more like a vintage Marblehead than the more recent ones. That stern overhang shortens the waterline length. The overhangs on full scale yachts were sometimes meant to shorten the waterline to give a more favorable rating. This could lead to some bizarre hull distortions. An extreme example would be Nathanael Herreshoff's Wanda.HMCo #490s Wanda https://herreshoff.info/Docs/S00490_Wanda.htm Check out the hull model on that page. Or look at the lines drawing by clicking on the thumbnail on the right. When heeled, the waterline would get longer. I wonder if Wanda wasn't faster "tacking" downwind rather than keeping a straight course.
Hi,
The intended use is on the pond, or even in sea if the quality of the finished boat encourages me. I guess the Marblehead is pretty quick and light. I'm not aiming particularly for a quick boat. My boat would need to be about 7.5kg to float approximately like on the pictures. The length of the fin keel and size of the sails will probably change when I find the will to do some calculations on them. And maybe an electric motor for low wind propulsion and interchangeable fin keel. It's all in the air. Hmm, that Wanda boat...
Here is the real equilibrium for the boat at 7.5kg:
Some work on keelbox and frame:
Texture and and Lighting in Blender
