just so it's decent quality and easy to smear. I'm only expecting to use like a cauchgun place a beed then trowl w/ like a bondo splachteler.
please send links of you'r expert suggestion .
remember I've never stripped enamel paint from a aluminum substrate.
so need you sort from best to wrst pro/con ect.
I definitely won't be using any aircraft paint remover those people that where killed
must have had little to none ventilation.
I did see evidence of the garage it didn't appear to be ventilated. it's sad when people ignore safety guidelines when using powerful chemicals.
edit: I have the process listed grind got that, step 2 clean can I clean w/ mineral spirits then prime? I was intending on doing star side just top of outside cabin/exposed rear transome skin then third stage/rear wall/door/inside gunwhales.
the primary objective is cover the exposed transome skin where I covered the sterndrive holes and added brackets for trim tabs/transducer.
I purchased the quart size of primer from jamestown distribetors for aluimiun hulls below water.
TotalBoat Aluminum Boat Barrier Coat Epoxy Primer https://www.jamestowndistributors.com/userportal/product.do?part=498239&engine=adwords&gclid=EAIaIQobChMImuKQ_YSj2gIV3rfACh359gZZEAQYASABEgI5XPD_BwE so transome gets done then the rest also has hierarchy.
painting vinyl I believe won't require any priming correct?
