Hi Pierre,
You say with your log example: "If you want to beat all the sailboats for comfort ratio and capsize ratio" that your log cannot be beat. And then you say:
"I will guarantee you it will capsize". So which is it?
Capsize ratio has a lot to do with displacement, beam, depth of ballast and ballast/displacement ratio and hence the righting arm.
Carl's Sail Calculator doesn't show ballast to displacement ratio (easy enough to figure out by dividing ballast/displacement), nor does it show directional stability or how close winded a boat a boat can sail.
Motion comfort is definitely an important factor in choosing a boat. Good capsize and motion comfort numbers coexisting are a plus. Carl's site is not perfect, but it is a rich source of data on many boats, and a good starting point.
I suggest that generally speaking, high capsize, and low motion comfort numbers together can indicate a less close winded boat that is less comfortable when sailing against choppy waves.
