It is a matter of "horses for courses", do you put a thoroughbred horse in front of a plow? when you really should be using a reliable draft horse? or do you put a jet turbine on the top of an outboard leg? and expect fuel economy and performance reliability as opposed to 1000mph speed? if you get my drift?
See post 21 and imagine a slightly shorter mast set a bit further back so the stays near midships went forward a bit so a furler could be used...
http://www.boatdesign.net/forums/showthread.php?t=21274&page=2 There would be reduced downforce to push the leeward hull deeper, easier to control, and no boom, (or attendant sheets & wenches etc), to decapitate or kneecap (ouch), you whilst reeling in those fish
Remember those earlier thoughts of yours to keep it simple, several smaller sails for ease of handling...
That rig on the foil is strictly for performance and demands constant attention... You will note that "Crash Helmets" were worn!!! So, make 2 boats, one 12m as "mother-ship" and small toys for the speed thing, carried on the aft bridgedeck roof, as there will be no "main" there to cause other problems...
Re post 70, "as I have it," - sometimes...
Look at the angle from the central mast and the forestays/furled sails and think of the reduction of bad down-forces... It helps to make a simple model to see where it is at... Look carefully and be pleased... not necessarily a "sailing model" but a convenient post, mark the boat with whitewash (tennis court marker from your tennis court) or even driveway and tent pegs to mark the bows then a bit of bedsheet (whilst wife is away shopping) and see how it sits...
