Comparison Testing Method
If you are interested in comparing two rigs under identical conditions you could test them against each other by putting them on the same platform. For example, take a floating circular disk, put rig A on one side and rig B on the other and set them so that they are working against one another. The rotation and movement of the disk should give you some insight into how the rigs behave relative to one another.
I'm liking your idea the more I think about it,.... now some thoughts.
I do realize that my rig is going to be the higher drag rig of the 2, if nothing more than its a 'ketch' with 3 sails rather than the sloop. So if I were to place the two experiments at an equal distance from the center of rotation of that big disc you suggested, its no doubt which one would win....not mine.
But what if I could make it so that the distance from the rotation center of the big plate could be varied,....then I might find a balance point that should be a good indicator as percentage of difference in the 2 by way of determining the difference in the radial arm of each rigs location on the plate :idea:
And that 'round plate' need not really be a big circular one, but rather could just be a 'rotating/swinging beam' connecting the 2 experiments.
In the end I might be able to show
visually that my rig will point as high, at least, as the sloop (if it is commanded to do so). And I will have some good idea of the relative drag/propulsion forces between the two without having to physical measure those individually and then scale them up, all of which can suffer in mathematical scaling problems.
