Worse design
Discussion in 'Boat Design' started by gonzo, Jan 26, 2010.
Thread Status:
Not open for further replies.
  1. frank smith
    Likes: 14, Points: 28, Legacy Rep: 185
    frank smith Senior Member
    I am sure you have one that you could post .
  2. Easy Rider
    Easy Rider Senior Member
    Why do you guys say these things. It's just bait and they'll just stomp on you again.
    Easy Rider
  3. woodworm
    woodworm Junior Member
    See that is real bad design.
    Function of this Hellwig Panther made in east germany
    Every little wave will overflow the boat while the boat is going slow .
    Best regards
    Erhard
  4. frank smith
    the stern fins look like they came from a 59 Chevy impala
  5. woodworm
    Hy Frank,
    I mend ; the terrible function of boat which came from the keel and construction design
    It is realy bad design when a 4,5 m boat is not able to take a half meter wave wile it is going slow.
    The cadilliac-fin design on the boat is well done and many people are loving the panther, but awful to be in the boat while the boat is not gliding.
    In boat design the function is nothing to discuss, the form can follow whatever she will but never make a boat dangerous.
    Acually I am building something looking little bit like that,But the hull will lay better in the water.
    have a look here if you wish
    http://www.boatdesign.net/forums/wo...oration/runabout-made-out-firewood-30712.html
    Sorry english is not so easy for me.
    Best regards erhard
  6. troy2000
    troy2000 Senior Member
  7. frank smith
    It looks like a small boat with a lot of weight in the front, and I would agree
    that it is not good . Is that the motor in the middle , maybe the distribution of weights is not good .
  8. hoytedow
  9. Loveofsea
    Likes: 6, Points: 0, Legacy Rep: -68
    Loveofsea New Member
  10. frank smith
  11. Willallison
    Willallison Senior Member
    I don't wish to dwell on such a controversial topic, and I apologise for not having seen it elsewhere, but perhaps you could post a pic of this mystical skiff of your Loveofsea....
    Frank,
    Difficult to say much from the images you've posted, but two things spring to mind immediately. The first is the already discussed extreme amount of hook in the bottom. It would cause pretty significant dynamic instability - even at quite low speeds. Effectively altering the shape of the bottom can be done already... with trim tabs. They are simple, inexpensive and effective. No poit trying re-invent the wheel with something that's bound to be the opposite on at least two fronts.
    The chine shape appears to be somewhat extreme, particularly up forward. Angling chines down at more than about 3 degrees can actually make a boat wetter. It will also tend to make the ride harsher and can tend to make the hull dig in. Combined with the hook bottom, I could imagine this being a nightmare in a downhill run....
    Lastly, on the aesthetic front, I agree, that triangle sitting on the deck doesn't appear to fit with any other aspect of the boats shape.
  12. frank smith
    I hope my new euro nove is more to your liking, I have made all the changes you have suggested, and converted it to a tunnel drive . the fins were added to give a subtle retro flair,very attractive if I do say so myself. i hope you approve and that we can come to an agreement on the final design soon.
    frank
  13. Willallison
    Impossible to tell really, just from that one angle, but it...well...errr... looks....err...dangerous. A befitting inclusion in this thread...:eek:
    ...sorry.....
  14. Joe Petrich
    Likes: 10, Points: 18, Legacy Rep: 141
    Joe Petrich Designer
    Has anyone considered that the boat in the video was designed to stuff the bow? Search for SeaDoo Challenger on Youtube. I believe that is the boat in the original video. As I recall the Challenger has two jet drives. When you dump the buckets into reverse at speed the back end naturally rises on the jets and stern wave and the low bow drops and momentarily buries itself, filling the shallow self draining cockpit. The boat will also do 360 and 720 degree turns due to it's flat bottom and differential thrust from the two jet drives. So it seems the boat performs as it is supposed to whether you like that behavior in a boat or not.
    Carry on!
  15. Sheepy
    Likes: 4, Points: 0, Legacy Rep: 61
    Sheepy Junior Member
    I am actually a professional fisherman and I can assure you, you have not been out in 50+ knots of wind without taking green water over the bow, unless you were actually in a small lake, not the ocean. Anyone that has actually been out in these kind of conditions would know I am right.There would be whitecaps bigger than your skiff.
    It is your kind of boneheaded arrogance that gets people killed, attempting to rescue people like you!
    The worst I have been out in is 70 + knots on the boat in the pic,(grey wheelhouse) your skiff would fit inside this boat 10 times over. She took green, white blue water completely all over her from every angle. Some of the whitecaps were twice the size of this boat.
Thread Status:
