Over the last 150 years, carbon dioxide (CO2) concentrations have risen from 280 to nearly 380 parts per million (ppm). The fact that this is due virtually entirely to human activities is so well established that one rarely sees it questioned. Yet it is quite reasonable to ask how we know this.
One way that we know that human activities are responsible for the increased CO2 is simply by looking at historical records of human activities. Since the industrial revolution, we have been burning fossil fuels and clearing and burning forested land at an unprecedented rate, and these processes convert organic carbon into CO2. Careful accounting of the amount of fossil fuel that has been extracted and combusted, and how much land clearing has occurred, shows that we have produced far more CO2 than now remains in the atmosphere. The roughly 500 billion metric tons of carbon we have produced is enough to have raised the atmospheric concentration of CO2 to nearly 500 ppm. The concentrations have not reached that level because the ocean and the terrestrial biosphere have the capacity to absorb some of the CO2 we produce.* However, it is the fact that we produce CO2 faster than the ocean and biosphere can absorb it that explains the observed increase.
Another, quite independent way that we know that fossil fuel burning and land clearing specifically are responsible for the increase in CO2 in the last 150 years is through the measurement of carbon isotopes. Isotopes are simply different atoms with the same chemical behavior (isotope means “same type”) but with different masses. Carbon is composed of three different isotopes, 14C, 13C and 12C. 12C is the most common. 13C is about 1% of the total. 14C accounts for only about 1 in 1 trillion carbon atoms.
CO2 produced from burning fossil fuels or burning forests has quite a different isotopic composition from CO2 in the atmosphere. This is because plants have a preference for the lighter isotopes (12C vs. 13C); thus they have lower 13C/12C ratios. Since fossil fuels are ultimately derived from ancient plants, plants and fossil fuels all have roughly the same 13C/12C ratio – about 2% lower than that of the atmosphere. As CO2 from these materials is released into, and mixes with, the atmosphere, the average 13C/12C ratio of the atmosphere decreases.
Isotope geochemists have developed time series of variations in the 14C and 13C concentrations of atmospheric CO2. One of the methods used is to measure the 13C/12C in tree rings, and use this to infer those same ratios in atmospheric CO2. This works because during photosynthesis, trees take up carbon from the atmosphere and lay this carbon down as plant organic material in the form of rings, providing a snapshot of the atmospheric composition of that time. If the ratio of 13C/12C in atmospheric CO2 goes up or down, so does the 13C/12C of the tree rings. This isn’t to say that the tree rings have the same isotopic composition as the atmosphere – as noted above, plants have a preference for the lighter isotopes, but as long as that preference doesn’t change much, the tree-ring changes wiil track the atmospheric changes.
Sequences of annual tree rings going back thousands of years have now been analyzed for their 13C/12C ratios. Because the age of each ring is precisely known** we can make a graph of the atmospheric 13C/12C ratio vs. time. What is found is at no time in the last 10,000 years are the 13C/12C ratios in the atmosphere as low as they are today. Furthermore, the 13C/12C ratios begin to decline dramatically just as the CO2 starts to increase — around 1850 AD. This is exactly what we expect if the increased CO2 is in fact due to fossil fuel burning. Furthermore, we can trace the absorption of CO2 into the ocean by measuring the 13C/12C ratio of surface ocean waters. While the data are not as complete as the tree ring data (we have only been making these measurements for a few decades) we observe what is expected: the surface ocean 13C/12C is decreasing. Measurements of 13C/12C on corals and sponges — whose carbonate shells reflect the ocean chemistry just as tree rings record the atmospheric chemistry — show that this decline began about the same time as in the atmosphere; that is, when human CO2 production began to accelerate in earnest.***
In addition to the data from tree rings, there are also of measurements of the 13C/12C ratio in the CO2 trapped in ice cores. The tree ring and ice core data both show that the total change in the 13C/12C ratio of the atmosphere since 1850 is about 0.15%. This sounds very small but is actually very large relative to natural variability. The results show that the full glacial-to-interglacial change in 13C/12C of the atmosphere — which took many thousand years — was about 0.03%, or about 5 times less than that observed in the last 150 years.
For those who are interested in the details, some relevant references are:
Stuiver, M., Burk, R. L. and Quay, P. D. 1984. 13C/12C ratios and the transfer of biospheric carbon to the atmosphere. J. Geophys. Res. 89, 11,731-11,748.
Francey, R.J., Allison, C.E., Etheridge, D.M., Trudinger, C.M., Enting, I.G., Leuenberger, M., Langenfelds, R.L., Michel, E., Steele, L.P., 1999. A 1000-year high precision record of d13Cin atmospheric CO2. Tellus 51B, 170–193.
Quay, P.D., B. Tilbrook, C.S. Wong. Oceanic uptake of fossil fuel CO2: carbon-13 evidence. Science 256 (1992), 74-79
from scripts
How do we know that CO2 is increasing in the atmosphere?
High precision measurements of atmospheric CO2 made by the Scripps CO2 Program and other organizations show that its average global concentration in 2006 was more than 381 ppm; about 70 ppm higher than the first direct atmospheric measurements made in the 1950s.* Records from Mauna Loa and the South Pole show nearly the same rate of rise over time; demonstrating that the rise is global in extent (see plot). Measurements from dozens of sites around the world now confirm the overall rise (NOAA/ESRL Global Monitoring Division). Almost all of these measurements have been made by high precision non-dispersive infrared gas analyzers which are calibrated using internationally agreed protocols.* The standards used to calibrate the instruments are subject to rigorous international quality control procedures and peer review. The result is a series of datasets made by several laboratories in both hemispheres all confirming the current increase in atmospheric CO2.
How fast is CO2 increasing in the atmosphere and is this changing?
The rate of increase of atmospheric CO2 shows large variations from year to year. Initial high precision measurements of atmospheric CO2 showed average growth rates of less than 1 ppm/year in the 1950s and 1960s. However in the latter half of the 20th century and in the first few years of the 21st century the average growth rate had more than doubled to about 2 ppm/year.
How do we know that the CO2 increase is caused by human activites?
Industry data provides detailed *figures of fossil fuels used in various sectors. This data can be used to calculate the amount of CO2 released into the atmosphere by combustion of the fuels. The emissions are more than sufficient to explain the observed increase in atmospheric CO2 Careful analysis of the atmospheric CO2 data collected by Scripps and other organizations shows that CO2 is increasing at a rate that is about 44% slower than would be expected if all the CO2 from the burning of fossil fuels stayed in the air. The real puzzle is to explain where the missing 44% of the emissions have gone. The answer is that this "missing" CO2 is absorbed by both the oceans and the terrestrial biosphere. On average over the last 50 years the oceans and the terrestrial biosphere have continued to "mop up" this amount of CO2. Whether they will continue to do this as atmospheric CO2 concentrations continue to increase is a critical question and the subject of intense international research.
Other evidence for a human cause: 1) There are no known natural sources of CO2 sufficient to account for the recent increase. 2) There are no known sinks of CO2 sufficient to have absorbed all the CO2 from fossil-fuel burning. 3) For more than 10,000 years prior to the industrial revolution, atmospheric CO2 levels were essentially constant (see below), which shows that the recent increase is not natural. 4) The increase in CO2 has been accompanied by a decrease in O2 (see AORG) and by changes in the ratios of the isotopes of carbon (see below) in the CO2. The O2 and isotopes changes indicate that the CO2 increase was derived from the oxidation of old organic matter - consistent with burning fossil fuel. 5) The pattern of CO2 increase since 1958 has closely mirrored that of fossil-fuel burning (see plot).
Isn't the Mauna Loa record influenced by CO2 emitted by the volcano?
If one looks at the minute-by-minute data from Mauna Loa, one finds rare occasions when the CO2 is elevated from emissions from fumaroles upwind on the mountain. The fumaroles are emitting constantly, so the timing of the events depends on wind direction and not changes in volcanic activity. These events impact only a tiny faction of the data and are easily distinguished from rest of the record. The reported version of the Mauna Loa record has been “filtered” to remove these events, as well as other certain other local effects, as described in the early publications (see Keeling 1960 Tellus paper).
How much has atmospheric CO2 changed since the industrial and agricultural revolutions?
When snow falls it traps air. In polar and other regions where the snow never melts it eventually forms ice and this air is entrained in tiny bubbles. Typically about 100 mls of air are contained in every 1 kg of ice. Thus polar ice acts as a kind of an "air museum" providing us with information on the composition of the atmosphere up to more than half a million years ago in the past. Extraction and gas analysis techniques tell us what the concentrations of CO2 were in the atmosphere before 1950. In addition they overlap the direct atmospheric measurements since the 1950s and confirm the present rate of increase.
CO2 concentrations measured from ice collected at Law Dome glacier in the Antarctic show that atmospheric CO2 has been remarkably constant at about 270 to 280 ppm over about the last 1000 years until the 18th century when it began to rise. As of 2005, the level had risen to 378 ppm, an increase of 35%. On the basis of ice core records the current CO2 concentrations are unprecedented*for at least the last 650,000 years.
What are stable isotopes in atmospheric CO2 and why are these measured as well as its concentration?
CO2 molecules are made from the elements carbon and oxygen. Both carbon and oxygen contain isotopes which are atoms with the same numbers of protons but different numbers of neutrons. Because of this, the mass of each isotope is slightly different and this leads to CO2 molecules with different masses. The most common isotope of carbon, 98.9%, is carbon-12 denoted as 12C with an equal number of protons and neutrons in its nucleus. Carbon-13, denoted 13C, has 6 protons and 7 neutrons in its nucleus and is much less abundant at about 1.1%. Both physical and chemical processes in nature can discriminate against the heavier 13C atom thus changing the 13C/12C ratio of molecules of CO2.
These changes are very small but can easily be measured using modern isotope ratio mass spectrometers to 1 part in 100,000.* Because different sources of atmospheric CO2 have different 13C/12C ratios isotope measurements of CO2 can be used to "fingerprint" CO2. CO2 derived from the combustion of fossil fuels, for example, has a lower ratio of 13C to 12C than carbon in the oceans or emitted by volcanoes.
from Lowenz,com
High precision measurements of atmospheric CO2 made by many scientific organizations around the world show that its average global concentration in 2008 was about 385 ppm and more than 100 ppm higher than its value at the beginning of the industrial revolution in the 18th century. Almost all of these measurements have been made by high precision non dispersive infra red gas analysers which are calibrated using internationally agreed protocols. The standards used to calibrate the instruments are subject to rigorous international quality control procedures and peer review. The result is a series of datasets made by several laboratories in both hemispheres all confirming the current increase in atmospheric CO2.
The rate of increase of atmospheric CO2 shows large variations from year to year. Initial direct high precision measurements of atmospheric CO2 showed average growth rates of less than 1 ppm/year in the 1950s and 1960s. However in the latter half of the 20th century and in the first few years of the 21st century the average growth rate more than doubled to about 2 ppm/year.
How do we know that the CO2 increase is caused by human activities?
Industry data provides detailed figures of fossil fuels used in various sectors. This data can be used to calculate the amount of CO2 released into the atmosphere by combustion of the fuels. The emissions are more than sufficient to explain the observed increase in atmospheric CO2. Careful analysis of atmospheric CO2 data collected by organizations around the world shows that CO2 is increasing at a rate that is about 44% slower than would be expected if all the CO2 from the burning of fossil fuels stayed in the air. The real puzzle is to explain where the missing 44% of the emissions has gone. The answer is that this "missing" CO2 is absorbed by both the oceans and the terrestrial biosphere. On average over the last 50 years the oceans and the terrestrial biosphere have continued to "mop up" this amount of CO2. Whether they will continue to do this as atmospheric CO2 concentrations continue to increase is a critical question and the subject of intense international research.
But how do we know that this increase in CO2 really comes from fossil fuel combustion? Well it turns out that carbon contains isotopic “markers” which are very like fingerprints (see below). The distinctive isotopic character of the carbon contained in fossil fuels is transferred to the carbon in the CO2 released into the atmosphere when the fuels are burned and can easily be found using modern analytical instruments. This isotopic marker or fingerprint has been measured at many locations world wide and is smoking gun proof of the fossil fuel origins of increasing atmospheric CO2 since the industrial revolution. Also when fossil fuels are burned oxygen is removed from the atmosphere and atmospheric oxygen measurements made at a world wide network of sites confirm that atmospheric oxygen has been decreasing in parallel with increasing atmospheric CO2.
When snow falls it traps air. In polar and other regions where the snow never melts it eventually forms ice and this air is trapped in tiny bubbles. Typically about 100 mls of air are contained in every 1 kg of ice. Thus polar ice acts as a kind of an "air museum" providing us with information on the composition of the atmosphere up to more than half a million years ago in the past. Extraction and gas analysis techniques tell us what the concentrations of CO2 were in the atmosphere before 1950. In addition they overlap the direct atmospheric measurements since the 1950s and confirm the present rate of increase.
CO2 concentrations measured from ice collected at Law Dome glacier in the Antarctic show that atmospheric CO2 has been remarkably constant at about 270 to 280 ppm over about the last 10,000 years until the 18th century when it began to rise. As of 2008, the level had risen to about 385 ppm, an increase approaching 40%. On the basis of ice core records the current CO2 concentrations are unprecedented for at least the last 650,000 years.
These changes are very small but can easily be measured using modern isotope ratio mass spectrometers to 1 part in 100,000. Because different sources of atmospheric CO2 have different 13C/12C ratios isotope measurements of CO2 can be used to "fingerprint" CO2. CO2 derived from the combustion of fossil fuels, for example, has a lower ratio of 13C to 12C than carbon in the oceans or emitted by volcanoes.
LONG-TERM OBSERVATION OF CO2 CONCENTRATION AND ITS ISOTOPE RATIO
OVER THE WESTERN PACIFIC
H. Mukai1, Y. Nojiri2, Y. Tohjima3, T. Machida4, Y. Shibata5 and H. Kitagawa6
Center for Global Environmental Research, National Institute for Environmental Studies, Tsukuba,
Ibaraki, 305-8506 Japan;
lnmukaih@nies.go.jp
2
Climate Change Research Project, NIES, Tsukuba, Ibaraki, 305-8506 Japan;
nojiri@nies.go.jp
3
Atmospheric Division, NIES, Tsukuba, Ibaraki, 305-8506 Japan;
tohjima@nies.go.jp
4
tmachida@nies.go.jp
5
Chemistry Division, NIES, Tsukuba, Ibaraki, 305-8506 Japan;
yshibata@nies.go.jp
6
Graduate School of Environmental Studies, Nagoya University, Furo-cho, Chikusa-ku, Nagoya City,
464-8601, Japan;
hiroyuki.kitagawa@nagoya-u.jp
ABSTRACT
Air was collected systematically from 1995 to 2005 over the Pacific from 30S to 55N in latitude by
ships-of-opportunity to monitor global trend of CO2 concentration and its variation in the atmosphere.
The monitoring results showed that three El Niño events during 10 years mostly affected regional and
temporal variation of CO2 growth rate and its budget. Variation of carbon isotope ratio showed that the
CO2 flux from terrestrial biosphere seemed to rapidly increase at that time, correlated with global
temperature anomaly. Oxygen isotope ratio had increasing trend in this period, similar to the variation of
temperature. Atmospheric 14CO2 variation also seemed to be influenced by El Niño event.
INTRODUCTION
Atmospheric CO2 concentration is increasing gradually by
anthropogenic CO2 input. For better understanding of CO2 budget in
the atmosphere, isotopic signatures of CO2 are often observed in
addition to its concentration. Global CO2 budget can be discussed
based on the difference of fractionation factors in the individual
sink processes (i.e. absorption by ocean and photosynthesis).
Although environmental conditions can affect the degree of isotopic
discrimination, photosynthesis by C3 plant can be most affective to
the temporal change (e.g. daily and seasonal) in carbon isotope
ratio. Oxygen isotope ratio of CO2 is not conservative parameter,
but can be changed through exchange reaction with oxygen of
water. Especially it is related to gross primarily production and soil
respiration. On the other hand, because radiogenic carbon is not
emitted by fossil fuel, 14C can be a good tracer of CO2 cycle. Fig.1 Recent ship routes for sampling
EXPERIMENTAL
Oceanic background air has been collected over the Pacific since 1995 by using commercial cargo ships.
We used two main ship routes for the sampling; JPN – Australia - New Zealand (southern route) and JPN
- Canada - USA (northern route). We could gain kind cooperation from following ships; as the southern
route, HAKUBA-MARU (Nihon Yusei) (1995), SOUTHERN CROSS (MOL) (96-2000), GOLDEN
WATTLE (MOL) (2001), GLORY (MOL) (2002), and FUJITRANS WORLD (Kagoshima Senpaku)
(2003-2005); as the northern route, SKAUGRAN (Seaboad Int. Shipping Co) (1994-1999), ALLIGATOR
HOPE (MOL) (1999-2000), PYXIS (Toyofuji) (2001-2005) and SKAUBRYN (Seaboad). Air inlet was
usually placed on a small mast at the bow of the ship. Air was drawn through the stainless steal tube from
the air inlet by a metal bellows pump and compressed in the 3L stainless steel canister up to 2.5 atm after
removing moisture. Sampling was done automatically about at least every 3 degree in latitude. GHGs
concentrations in the canister were measured by usual methods. CO2 was extracted for further isotopic
analysis. Isotope ratios were measured by usual dual inlet method (MAT252). 14C was measured by
accelerator mass spectrometry in NIES.
RESULTS AND DISCUSSION
For recent 10 years (1995-2005), 18-20 ppm increase in
concentration was observed in all sampling latitudes.
Observed CO2 growth rate was relatively higher than that of
longer average (1.6 ppm/y) from 1985 to 2001 [WDCGG].
High CO2 growth rate over 3 ppm/y was observed in
tropical area in 2002 following the case at the last El Nino
in 1998. In addition to the increase of anthropogenic
emission from 5.4Gt/y to about 7 Gt/y through 20 years
period, El Niño events associated with relatively high global
temperature seemed to affect rapid CO2 growth increase.
Decreasing rate of carbon isotope ratio was about 0.025 per
mil/y during observed period with a large decreasing rate of
0.08 per mil/y at El Niño year. To estimate the global budget
of CO2, atmospheric volume weighted average was
calculated. By using simple global flux equation by Francey
et al. [1995], oceanic and terrestrial net CO2 fluxes were
roughly estimated. In three El Niño years of ’95, ’97/’98
and 2002, terrestrial sink was found to be very small or even a small source (1 Gt/y), causing high CO2
growth rate about 3 ppm/y. On the other hand, in La Niña year of 2000, terrestrial sink was large (2 Gt/y).
Oceanic sink was fairy stable at about 2 Gt/y with a small increase (around 1 Gt/y) at El Niño period and
small decrease in La Nina period. (In 2002 El Niño year, change of oceanic sink was much smaller than
that in ’97 El Niño). Such apparent fluctuation of oceanic sink may be partly explained by the variation of
isotopic discrimination by photosynthesis and /or contribution of C4 plants [Randerson et al., 2002].
Fig.2 Latitudinal average trends for CO2, δ13C
and δ18O.
Oxygen isotope ratio had a weak increase trend during the observed period, which was a little different
tendency from previously analyzed trend during 1993-1998 by Ishizawa et al. [2002]. It also had a local
maximum in El Niño year, when the CO2 growth rate became high. Such variation may be correlated with
temperature. Because equilibrium in δ18O of CO2 with water will give a negative effect against
temperature increase, other factors such as increase of δ18O of water in the soil and plant by dry condition
and/or rapid decrease of gross primarily production may be related to the δ18O increase.
Data of Δ14C at 15S and 25N had a systematical gap (about 5 permil) and both values continued to
decrease with a decay time of 16 y. In El Niño year 14C seemed to show weak positive anomaly. It may
suggest the possibility of showing rapid flux of CO2 from terrestrial biosphere.
REFERENCES
Francey, R. J., P. P. Tans, C. E. Allison, I. G. Enting, J. W. C. White and M. Trolier (1995), Changes in
oceanic and terrestrial carbon uptake since 1982, Nature 373, 326-330.
Ishizawa M., T. Nakazawa and K. Higuchi (2002), A multi-box model study of the role of the biospheric
metabolism in the recent decline of δ18O in atmospheric CO2, Tellus 54B, 307-324.
Randerson, J. T., G. J. Collatz, J. E. Fessenden, A. D. Still, J. A. Berry, I. Y. Fung, N. Suits and A.S.
Denning (2002), A possible global covariance between terrestrial gross primary production and 13C
discrimination: Consequences for the atmospheric 13C budget and its response to ENSO, Global
Biogeochem. Cycles 16 (4), 1136, doi:10.1029/2001GB001845.
