...The max stress Von Mises is 241 MPa in Fusion and 287 MPa in Scan and Solve so very close...
But the solution to a bar/beam of those dims with a load of 10kN is 160MPa.
Thus it is not correct .. beam theory tells you that.
It is difficult to tell in the images, but is the mesh made of squares?
What is the thickness, I can not see any notation? Your input is "force", and the output is "pressure" alt. "displacement".
... The software calculates the Von Mises Stress value in a solid made of a particular material subject to a particular load...
....The max stress Von Mises is 241 MPa in Fusion and 287 MPa in Scan and Solve so very close...
So, the logical next step would be to increase the thickness enough to make it a 3d solid and check the validity of the von Mieses theory in both applications. ...
Yes, I am completely with you on that. My suggestion is aiming to see whether the software is introducing something that should not be there. The stress level indicated (zero to max) can not occur, unless there is a tensor in the length direction. In the classical beam theory the "holding" moment is created from the integrated stress in the span -160 to +160 Mp; a total of 320 Mp from max to min. The integrated moment from this is greater than the softwares that show between 240 and 280 Mp in total.This is a a simple beam 2D problem, there is no z-axis component, thus the stress in this direction is always zero.
....My gut feeling here is that the combined stress calculation in the software is using expressions based on some "sum-of-squares" calculation, which too often gets mixed with the "square-of-sums", which is not equal.
...the combined stress of bending and shearing should not be lower than the single value for bending.....? ..
Hello Andrei,
On your last example (llustration just above) with the collision into the keel simulation, where have you positionned the restraints ? e.g. sheerline, rig, etc ??
Thanks, Ed
