"Vision Marine Technologies Testing Electric-Powered 32-Foot Cat With 100-Plus-MPH Goal In Mind
Jimboat
Senior Member
Joined
Feb 9, 2002
Posts
280
Reaction score
31
Location
Canada
With modern Lithium Nickel Manganese Cobalt Oxide (NMC) battery banks the 16kWH you need for a speed run is only ~106 kg, so about the size of a 30 gal fuel tank....but only 3 minutes of power.
One motor controller design I worked on drew only 2 KW, but still needed a dry ice cooling system in the lab. What kind of cooling system has been designed in to prevent motor winding insulation from melting and shorting?
Not sure from the article, but must be the same cooling system that cools the dual 160 kW OBs.
The tradeoff on run time is exceptionally disappointing.
But, perhaps these efforts are how the envelope needs to be pushed.
How much horsepower is needed for 100 mph from a conventional outboard? As for cooling why not mount the entire thing underwater and get it water cooled for free? Of course there is the electronics.
