M&M Ovenden
Senior Member
- Joined
- Jan 15, 2006
- Messages
- 365
- Reaction score
- 80
- Location
- Ottawa
While the term "load" is fairly vague, it's implied that it is an element in a circuit that consumes energy, the source supplies the energy. A load can be resistive, capacitive, inductive or a combination of them all. As I've show with above examples a load can draw constant power from a battery (constant power load) - I was pointing this out about your comment: "As the battery discharges, the voltage goes down. Therefore, the power output also goes down." is not always true.
Most loads these days have switching regulators on the front end. This doesn't apply to motors - but they are fairly tolerant of input voltage.
I did not quantify DoD, I have only noted that I am happy to follow industry standard definitions. I understand these have various limits and I find it is possible to work within this framework.
I think that wraps this up.
Cheers,
Mark
I thought you agreed with them also by the above comment.The industry does not need to change the standards. I test batteries to those standards and they work well.
Cheers,
Mark
