peterraymond
- May 19, 2009
- 81
- Colorado
High aspect ratios
I have compared probably the simplest Savitsky equation to the high aspect ratio calculation in Fluid-Dynamic Drag by S. F. Hoener. I found that somewhere before an aspect ratio of 5 the Savitsky calculation gave a higher lift coefficient than airfoil theory would give for even an infinite aspect ratio.
With a stepped hull the pitch angle is controlled by the geometry of the step and you typically can have higher aspect ratios, at least at higher speeds. The higher aspect ratios have better lift to drag too. I'd just suggest being a little careful and confirm with some reasonable reference that you are in a regime were Savitsky is valid.
Savitsky is I think also simplified compared to many real boat hulls. Ocean racing deep-V hulls all have strakes that are spaced and optimized, including ones that control trim angles by not going all the way to the transom. Maybe for this case Savitski would over estimate drag.
Many high speed boats also use air pressure to produce lift and isn't this outside Savitsky too?
