The goal is to somehow enable the boat to be more efficient at sub plane speeds. The boat has a fairly significant bow wake, and the bow just begins to rise at around 10 knots. She is not on what I would consider a full plane at that point by any means. If by converting the boat to a single screw with the same power as the twins, thus reducing the weight, and drag associated with the second outdrive; would that likely result in greater sub plane efficiency? Or would the boat plane at a lower speed possibly based on the reduced weight & drag?
Yellowjacket,
You say that the " objective of planing flaps is to increase surface area" and "if the flaps are kept level with the planing surface"
If you were merely to add planing flaps onto the back of the boat to increase planing surface area, you will have added planing surface area to the boat where the pressure is at the least amount. The longitudinal pressure distribution is highest at the stagnation line, prox 1/3 back from the leading edge of the wetted surface and a relatively linear slope to the transom. ie the back of the boat has the least amount of lift per square inch. I say zero, yellowjacket has said less than zero.
The purpose of planing flaps to is to provide additional lift at the transom. In order to maximize lift the flaps should have a higher level of attack than the hull. That is why they make them hydraulically adjustable.
When you drop the flap down wrt to the hull, the water at the flap changes direction with a corresponding increase in vertical lift which lifts the back of the boat. Certainly there is a drag component but the expense of this small drag, is nothing compared to the reduction of the drag due to the bow dropping down.
Additionally, if you put the flaps on correctly, you can optimize the lift component up at the stern vs the horizontal drag on the hull
We have discussed transom ventilation and at 8 - 10 knots, it should be ventilated. If you were to attach the flaps so they are say 1/2 inch up the transom, not more, This will leave the bottom of the transom ventilated, so when you drop the flap into the water stream, you create a new stagnation line on the flap. As I said earlier, a stagnation line has the highest pounds per square inch pressure than other spots on the hull. As Yellowjacket stated, make them as long as possible, so that you maximize the length of the stagnation line.
Additionally, the horizontal drag component will also create a moment around the center of lift which helps push the bow down.
In summary
Mount the flap slightly up the transom to ensure that you have transom ventilation just before the flap, which will produce a new max pressure stagnation line with minimum drag
This concept is not new, stepped hulls benefit from the introduction of more than one stagnation lines.
Our current boat at 44 feet cruises at 20 to 22 knots depending on loading conditions.
knots, with the tabs up. If I play with the tabs and drop the bow 2 - 3 degrees, I can often pull up to another 2 knots out of it at the same rpm.
As it sounds like you are in a high angle of attack, your efficiency should exceed this.
Please look at the link that I sent you for the larger maxum as you really do not want to be running bow up as the mpg close to the so called hump speed is not very good.
The best mpg usually occurs a few knots past the point where the bow becomes to come down due to its speed. ie if you are thinking that you are efficient at speeds just below the hump, you are not correct
From the perspective of an observer on the boat the freestream velocity of the water is 30 knots. From the same perspective the water changes speed as it goes past the boat, in some areas it is faster than 30 knots, and in other areas it is slower than 30 knots.
From the perspective of an observer in a position fixed to "earth" who takes an instantaneous snapshot of the water as the boat passes, the water near the boat in some areas is moving in the direction opposite the direction the boat is traveling while in other areas it is moving in the same direction as the boat.
The analysis can be worked from either perspective but one may be more convenient than the other.
Mikko, thanks for the excellent example.
The velocity as seen by the observer watching the model sail by is frequently called the perturbation velocity in hydrodynamics and aerodynamics.
But many believe that the proof of existence of buoyant forces after transom ventilation
lies in the fact that at an instantaneous instant, the hull is displacing some water therefore, buoyant forces are at work in conjunction with planing forces. In a totally static position, buoyant forces act at 90 degrees to the surface, but when planing the forces act at some angle to the surface. I always consider buoyant forces to be vertical although I can see other possibilities such as near the side of a steep wave.
In any case, I think that we have had some good discussion on this topic but I would still like to see a quantitative paper on the issue. Agreed.
