I’ve studied older posts on this topic, so I think I have an informed question here. I own a 24ft, 1973 fiberglass SeaCamper, which is more or less a cross between a houseboat and a speedboat. I’m in the middle of a complete overhaul of the boat and have replaced all of the wood structural members. The boat has new stringers, transom plywood, and transom knees, all properly glassed and tabbed and ready for up to a 200 hp outboard (per original SeaCamper designer notes and other owner experience). The old GM I/O engine is gone. I am re-powering with an outboard for all the typical reasons people do this (not the topic of this inquiry).
Here's a couple of photos of typical SeaCampers:
The straightforward thing to do is to install an outboard bracket on the reinforced transom. No problem there, as many SeaCamper owners have done so. However, I only need to power the boat to achieve 5 to 7 mph as our cruising grounds are the NY State Barge Canal. We just don’t need to go 25 mph when the speed limit is mostly 10mph and lower. We like life in the slow lane. I will hang just about any good condition, used 40-60 hp 4 stroke outboard on the transom if the price is right. I can’t afford a new or used 200hp motor, and I think an engine that size would be a fuel hog at slow speeds. Here’s my question:
Is there anything I can do with the design of the outboard bracket to improve slow speed performance of the boat? While I doubt we will achieve the .75 gal per hour fuel rate at 7mph of say a Nimble Nomad (similar size, weight, and power), I can’t help but wonder if a relatively inexpensive bracket modification could help.
Here’s a sketch of the aft section of the hull showing a conventional outboard bracket dimensioned closely to those one can buy off the shelf for a 25 inch shaft engine.
This is what the bracket manufacturer recommends when repowering an I/O with an outboard for planning hulls. I can get this bracket in aluminum, delivered and ready to mount for a tad under $1000.
I could also have the bracket made to extend the shape of the hull bottom, more or less as shown here, in the interest of easing the flow of water from the deep vee stern, perhaps causing a bit less water turbulence and maybe better fuel economy and handling:
The up-charge would be about $250. Would this be worth the expense?
Either way, the bracket is rated up to 300hp. When I sell the boat a new owner could mount a bigger engine and plane away (which is one reason I chose not to build the bracket myself out of ply and glass). Would the fuller bodied bracket negatively affect planning performance?
Or should I just bolt on the conventional bracket on and enjoy the boat for what it can and can’t do? And no, I can’t buy a different boat. I’ll have about $10K in the SeaCamper when I’m done, so it’s a pretty cheap houseboat, all things considered.
Thank you,
Tim Jennings
Enfield, NH
Thank you,
Tim Jennings
Enfield, NH
