You mentioned in your second post the equation that many contributors use to determine a theoretical maximum hull speed. This equation does not apply to planning hulls. It is a number that pertains to displacement boats only. Displacement hulls are slow moving hulls which move the water slowly out of the way, and then let the high pressure area, that it has built up ahead of say the midpoint of the boat, the boat recovers some of this energy toward the stern. For illustration purpose only, if you were to drop a ping pong ball ahead of the boat on the centerline, the pingpong ball will stay against the hull and exit at the centerline at the stern. Pressure recovery,
But you have a planning hull at planning speed, and this fictitious ping pong ball would run down the side of the boat until it hits the transom and separates from the hull at this point, The hull is supported by hydrodynamic forces only, and the weight of the boat is supported by this hydrodynamic force,
So by planning speed, I guess you are meaning at what speed will your boat plane. The definition that I would use for a boat that has a planning hull design, square transom, straight lines in the last half of the boat (could be warped but lets leave this out) is the speed at which you can see the entire transom of the boat. Ie the water that was turbulent behind the transom but still offered some displacement buoyancy is gone and the hull is completely supported by the hydrodynamic forces.
What has more impact?
Take your 29 foot planning hull
I assume that it is a deep v which gives a good ride in rough water. If you were to flatten the bottom of this boat, a lower v, this boat would plane at a lower speed
If for your current boat, you take 2,000 pounds out of it, the boat will plane at a lower speed as you do not need to create the same amount of hydrodynamic lift
If for your current boat, you could add say an additional 1 foot in width, you would increase the length of the high pressure stagnation line, the boat would plane at a lower speed.
So hull shape is paramount, as is weight.
Re what has more impact on planning speed, weight or hull shape
A planning hull
