I am an avid inflatable RIB user. I love them for there stability, rough water handling and lesuire lifestyle on the water.
I dislike them for very low freeboard and feel of being to close to the ocean.
Pangas seem like a workhorse very fuel efficient and multipurpose hull. But from what I see they can be a wet and unstable ride.
What about a hybrid with inflatable collars around a panga hull. With the back portion of the tubes down at water level to really increase stability, and then having the tubes follow the boat lines to have them high above water line from mid ship to bow, this would really improve the splash control.
I have a 32ft ACB rib boat (photo attached) , it is essentially a 29ft hull 7ft beam deep vee hull welded aluminium with welded in air chambers and the tubes on the outside that do exactly as above. Problem with it is 8000lbs and built like a tank, fuel hog. It is overkill for my needs. It was originally built for the military. But it is an awesome boat so great for the adventure/recreational fishing type boater. Dive door on the back that levels to the tubes so easy in and out. Walk around the tubes when at idle or dock. Sun tan on the tubes, swim in and out etc. Big pillow in the marina.
I see the panga as a great boat with a few downsides. Tubes might really help the stability without adding weight. Yes tube are expensive but most are not into boating to save $.
If you look most RIB mfgs are coming out with hybrid boats ( zodiac, Highfield has come out with the adv7 etc)
Anyone with panga experience care to way in on what they think tubes would do to the design?
Just considering options for my next boat design.
