Elefterios
New Member
- Joined
- Dec 8, 2022
- Posts
- Reaction score
- Location
- Greece
Hello everyone,
I have this ambitious plan to build my own sailing boat. I got inspired by my professor from high school who built his own wooden sailing boat. So ever since I kinda had it on my to do list.
I like building stuff and doing DIY projects (on land) but nothing compared to this crazy plan of mine. This will most likely be my ultimate construction project so im going to take things really really slow and try to learn as much as I can. Apart from having some designing skills, I have very minimum knowledge of ship building / hydrodynamics/ sailing etc.
Before I start seeking other information about boat building I would like to know if such idea is actually doable or not.
The sailing boat I have in my mind is about 12 meters long with two cabins. I am the kind of person who is obsessed with objects and materials that are maintenance free. So my initial thought is to build the boat frame with stainless steel (304 or 316) square tubes and use stainless steel sheets on the exterior to cover the frame. Materials that may be expensive, but are not hard to get.
The plan is to acquire stainless steel rectangular or square tubes for example 80x40mm 3mm thickness, bend each one at the appropriate radius and mig weld them to make the frame. Use 4-5mm stainless steel stripes / plates to cover the frame by welding them into it.
The first main questions are:
A) will such structure be possible to make with this method?
B) will stainless steel as a material for a sailing boat work at sea? Will it need to be painted? Every when? If polished to a mirror finish will it be better than painting it?
I know this is a crazy idea for someone with no marine background to build such thing. but if ancient civilizations could build boats some 3000-4000+ years ago, then I would feel ashamed if I cant build something that will float on water.
All information will be much appreciated!
Thank you!
Thank you!
