Angélique
aka Angel (only by name)
- Joined
- Feb 15, 2009
- Messages
- 3,003
- Reaction score
- 338
- Location
- Belgium ⇄ The Netherlands
This thread is a split off of the thread: "Life Tender" as an alternative to life raft
( side note: there was a thread title change + moderator note in post #47 )
Below the split off posts #17 & 18
Van De Stadt Design ---> History
‘‘ In 2008 the STADTSHIP 70 was created. This high performance cruising yacht with 1 ½ t removable water ballast, offers an excellent sailing performance while being a comfortable and safe passage maker. A remarkable feature of this yacht is the extensive pneumatic system for operating bow thruster, windlass, bowsprit, transom door and water pressure system. The yacht also has hidden airbags which can be used to keep this large yacht afloat in case of emergency. ’’
KM Yachtbuilders ---> Stadtship 70 ---> PDF Specs (drawings on page 8 + 9 + 11)
Now I'm wondering about these things...
- 1. - What areas are to be filled with the airbags ?
- 2. - How many m³ is to be inflated ?
- 3. - What will the new waterline be ?
- 4. - Is the airbag system set off automatically or by manual input ?
- 5. - Which spaces are planned to be used by the survivors ?
- 6. - Are those safe zone areas still dry or pumped out or drained after the airbags have inflated ?
- 7. - Are they able to reach freshwater and food supplies plus dry warm clothes ?
- 8. - What working communication options do they have there ?
- 9. - Will the boat still be a bit sail able ? (maybe with a jury rig if the mast also has broken off in the emergency)
10. - Will there even be some form of auxiliary propulsion available ?
11. - What will the stability range of the partly flooded / partly air bagged / partly safe zoned boat be ?
12. - Will the boat right herself after air bagging if she also has capsized in the unfortunate emergency ?
13. - Is the system ever tested, and to what extent, or is this based on theory only ?
Alas I'm not in the market for this boat, so rather than bothering the designer and builder with my curiosity I like to bring the topic up for discussion here . .
this is way I'd like a system to inflate something inside the boat to keep it at least on the surface decks awash
shouldn't be too hard to make it fully automatic when it senses a couple feet worth of water inside the boat.
then you'd still have the boat's food and water, clothing, etc, and much better chance of savage.
So I was surprised to see this feature on the Stadtship 70.When something automatically inflates inside the boat then someone could get trapped and suffocate as a result, and automatic systems need maintenance, and even then can fail, and the partly flooded boat with the other part filled with inflatable flotation would become inaccessible to reach the food, water, clothing, etc. inside. It would be better to have sufficient permanent built in flotation to reach your goal, I think.
Length over all 21.00 m
Length waterline 18.60 m
Beam 5.10 m
Draft 2.90 m
Displacement 29.0 t
Ballast 9.0 t
Sail area 230 m²
Beam 5.10 m
Draft 2.90 m
Displacement 29.0 t
Ballast 9.0 t
Sail area 230 m²
Length over all: 21.00 m / 68.90'
Length waterline: 18.60 m / 61.02'
Beam: 5.10 m / 16.73'
Displacement: 29 ton
Water ballast: 2 × 1500 L - (so 3 m³ ~ 3 tons there)
Draught: 2.90 m / 9.51'
Sail Area: 230 m²
Sail Area: 230 m²
