The Opera House Cup is open to the following sailboats:
26'0" min LoA,
"wood or wood-based cold molded hulls",
And to the following divisions:
- Vintage: ‘V’ Yachts designed before January 1, 1950 and built, maintained, and restored with materials and methods consistent with the original design.
- Classic: ‘C’ Yachts designed on or after January 1, 1950 whose rudders are attached to the trailing edge of the keel with at least one pivot point on the sternpost, and that are rated by CRF with Keel Type 5 or Type 6.
- Modern Classic: ‘MC’ Yachts designed on or after January 1, 1950 and typically before January 1, 1975, whose rudders are separated from the trailing edge of the keel and that are rated by CRF as Keel Type 3 or Type 4.
- Spirit of Tradition: ‘SoT’ Yachts typically designed on or after January 1, 1975 whose rudders are separated from the trailing edge of the keel and that are rated by CRF as Keel Type 1,2,3, or 4, and whose design embodies an appreciation of classic yacht or traditional workboat shapes and aesthetics. There are no restrictions on rigging, equipment, or construction materials and methods for Spirit of Tradition (SoT) yachts.
So, IF the Fairey Fox were 26'0", since it was designed before 1950, it would be eligible in the Vintage Division.
If I were to take the Fairey Fox design, stretch it 1.5ft to 26' LOA, then it would be a new design, and would need to go in the "spirit of tradition" division, which prohibits hard chines.
So, I'm basically looking for a 26'0", centerboard, wooden sailboat design that already exists. Because if I have to design my own, then I have more restrictions.
I could build a custom, stretched 26'0" adaptation of a pre-1950 design, but that's a lot of time/money/effort to create a boat that may be rejected because it's not clearly a Vintage design, and doesn't satisfy Spirit of Tradition criteria.
Here's a rundown of what we have so far:
Raven - too short
Fairey Fox - too short
E Scow – too long (for me to get a mooring)
Alerion 26 – not centerboard.
Flying 20 – only one built, and in a museum, and not centerboard?
Ipswitch Bay 26 – zero built, post-1950 design?
Thames A Rater – not suited to 1-2 ft chop, and none available in USA?
Atalanta 26 – too slow. Maybe none left.
Jollenkreuzer 20er – promising. but none available in USA?
Thousand Islands Yacht Club One Design – Promising. I can’t tell if it was centerboard? None left?
Renjolle – promising. but none available in USA?
