A bit curious about the possibilities of the "FreeShip", I imported a chine hull (an inverted-W) via a text-file to see how it works (a bit of mental excercise.......). The hull was originally created in Cadkey and we built some of these back in late 1990:ies, so I know it worked, and it would be nice to compare the panel development procedures. Import dimensions are mm (not m.), and hydro calculations are ok, as long as the open patch is not "wetted".
Now, the import works fine, except for a triangular patch in the outer bottom panel, which is excluded from the surface creation, see picture. As you can see, there is a transverse red control edge that should not be there, and I can't figure out how to get rid of it.
Anybody providing an explanation?
