Note: This feature may not be available in some browsers.
Ugh. Coincidentally I just got a Delftship update to 7.xxx.
It's horrible. Interface has been completely upended, and graphics quality has gone down the tubes. Ok, so much for keeping it updated.![]()
Ok, this is what I have at the moment. The file for the Herreshoff/Gardiner is done partially from memory (I used to see them every day), and partially from dimensions and drawings found online. The problem is with the latter, which everyone seems to have slightly different. Hey ho.
If someone has the actual table of offsets for any versions of this boat (original Herreshoff, or modified by Gardiner) I'd be happy to model it, on the basis of a gentlemen's agreement that I wouldn't use said table of offsets to build a boat. I'm not actually interested in purchasing plans for the boat since I'll probably never build one anyway, and the close approximation is good enough for my interests.
Same applies to the files for the Grant "Virginia" guideboat. I made two of these: one trimmed level and one trimmed aft one degree (guideboats are often rowed trimmed by the stern). The hull is only modeled to a height of 200 mm above the baseline, which is probably adequate. Can take it higher if necessary.
I also have a file D Cockey exported from Rhino, for a Rushton Saranac Laker (another guideboat). I haven't included that because it needs fairing and I still haven't got around to doing this. I'll make an effort on it, since the Saranac Laker is the prototype for the modern guideboats produced by some builders, so is probably one people are likely to encounter outside the Adirondacks.
Anyway, the other three are attached. No rights reserved. Do wotcha like.![]()
1903-1906 Saranac Laker[/url]
I'm going to whip up a full model for this one. The term "Saranac Laker" is a generic Rushton term which covers quite a range of guideboats over the years, with different lengths and beams. This seems like a good example to use.
Yes it will still do Michlet offsets, once you find the carefully hidden export menu.Thanks for the warning. I just downloaded the update but haven't upgraded my version.
I only use it to generate Michlet offsets, so as long as that feature is still there I'll be happy.
My Rhino model of the Rushton Saranac Laker was based on the offsets from the Adirondack Museum plans, presumably the same which NoEyeDeer found. Mean deviation of the Rhino surface from the published offsets is 0.004 inches, maximum deviation is .011 inches. The surface looks fair to me, certainly good for any analysis purpose or building a new boat.
The Saranac Laker plans were published in Rushton and His Times in American Canoeing by Atwood Manley, pp182-3, and are/were also available as single sheet from the Adirondack Museum. The museum also has plans for several other guideboats.
The original L. Francis Herreshoff rowboat design originally appeared as a lines drawing in the October 1947 issue of Rudder magazine, and were later reprinted in The Common Sense of Yacht Design p 137. I don't know of any published offsets by Herreshoff, and there may never have been any offsets.
Plans for John Gardner's (not Gardiner) interpretation were originally published in National Fisherman and were reprinted in Chapter 1 of Gardner's Building Classic Small Craft Volume 2.
It's probably fair enough in general, but is missing the stem and sternpost, as well as the sheer, and doesn't have the chine at the edges of the bottom board.My Rhino model of the Rushton Saranac Laker was based on the offsets from the Adirondack Museum plans, presumably the same which NoEyeDeer found. Mean deviation of the Rhino surface from the published offsets is 0.004 inches, maximum deviation is .011 inches. The surface looks fair to me, certainly good for any analysis purpose or building a new boat.
TBH, if you only want to include one fixed seater by default, I'd be inclined to use a guideboat. This is simply because they are the benchmark for speed in traditional fixed seaters, and are definitely faster boats than the Herreshoff/Gardner boat.Thanks, David.
I'll think about the hull I'll use as an example for a while.
It's also impossible to work with in Delftship, should anyone want to. The problem is that the way Rhino has exported the control net makes it useless in Delftship. You simply cannot modify it slightly and expect it to remain fair. To get a useful baseline model for experimentation in Delfsthip, it would be far easier to just make a new model, with a clean and usable control net, to the same table of offsets.
