Are you sure you really want to know?
First off, I’ll tell you my background so you can weigh my input accordingly. I am not an old salt and even several nautical terms you used, I had to go look up. Although, I have only designed and am building a 20’ beach catamaran, my next project will be a ~40’ cruising catamaran. I’d like to pursue designing and building a composite mast for both. Although the rig I plan for it is radically non-conventional, many of the design criteria will be the same as you need to address.
I was in the aerospace field. I designed composite structures for extremely low weight and with no safety factors. If we keep this thread going someone with more direct experience may weigh-in and help us or at least keep us from overlooking something important.
There are three schools of thought here. (1) Radical (I had to work this way in A.S.) – try to nail down every possible loading condition, every environmental condition, life expectancy and so forth and so on till we drill ourselves down and come out in Australia or in your case Atlanta! (2) Conservative – we build so that it mimics the metal structure. Rarely does this reduce weight significantly (or at all), but it gives a baseline. Besides, you may not really be looking for that last pound of savings or last psi of stiffness. (3) Start with 2 and evolve it with more specific knowledge and taking advantage of a laminates ability to readily change over the mast’s length. This is the one, I think we should take.
Hopefully you have access to Microsoft XL so we don’t have to try and write equations here. Plus, it allows for dynamic changes… for us and anyone else that wants to participate. I’m going to use inches and pounds as I can’t get a feel for it in metric. If someone else is interested in adding to it, they could flesh-out the metric columns next to the English units. I’ll leave room. Who knows… someone might take pity on us and just supply us with a better spreadsheet.
Anyway, this first-cut is based on simple mechanics of materials approaches. I’m currently reading “Principles of Yacht Design” by Lars Larsson & Rolf E Eliasson and I hope it will shed some more real world experience into our design.
See attached Spreadsheet. It might be a little daunting depending on your background, but apparently, you were doing some calculations concerning a fiberglass mast. If you need some clarification, let me know.
For a reality check, I’ve plugged-in your aluminum mast’s geometry into the spreadsheet. Using the same geometry (with your 4.5 mm wall thickness) it requires the longitudinal plies of a glass/epoxy design to have a thickness of 5.9 mm. This makes sense, since the glass/epoxy is less stiff than the aluminum and the design is driven by Euler buckling.
Placing your proposed 50% increase in the spreadsheet allows the thickness to be decreased to 1.63 mm. (Note again: This is only the zero degree plies)
It’s beyond the capability of the spreadsheet to do Laminated Plate Theory (LPT) calculations. So based on the zero degree plies needing to account for 1.63 mm, I’ve created a laminate using 0.008” plies with a stacking sequence of [90/45/0/0/0/-45/0]s for a total thickness of 0.112” (2.8 mm). Using an LPT program I have access to, resulted in a laminate with the following properties:
Exx = 5.9 Msi
Eyy = 3.7 Msi
Gxy = 1.6 Msi
thick = 0.112 in
SxxC = 22.6 Ksi (First resin failure)
SxxC = 81.7 Ksi (First fiber failure)
Plugging these back into the spreadsheet to get margins, we get…
- You would hear matrix cracking at 60% of the yield strength of aluminum.
- Final failure (mast breaking away) at 210% of the yield strength of aluminum.
- Euler Buckling at 130% of the aluminum mast
- Bending stiffness 130% of the aluminum mast.
- Weight 69% of the aluminum mast.
Things to be concerned about
- Some of the material properties are questionable. They came from aerospace grade pre-preg material, vacuum bagged and autoclaved at 350F and 100 psi pressure. Doing that with room temperature resins will obviously be impossible. This should not affect the buckling and bending stiffness numbers much. But it would most likely reduce the strength numbers by some. It’s hard to tell, until actual properties are generated with the glass/epoxy chosen.
- Also, the numbers are based on achieving 78% fiber volume in the laminate. Again, this is very hard to achieve even with an autoclave and pre-pregs.
- Local buckling was not checked as doing that for an orthotropic laminate is rather difficult and I currently don’t have the equations available to run that. However, having the 90 plies on the outside reduce wall buckling considerably. And if really concerned using rigid foam for a core would totally eliminate any possibility of wall buckling.
- Getting the 0 degree plies absolutely strait. When I finally get around to trying it, I will try to make some end pieces so that I can stretch the plies while they’re curing to ensure they are absolutely strait.
NOTE: THIS IS STILL WITH A UNIFORM LAMINATE OVER THE WHOLE MAST.
Things could definitely be improved; both the reduction in weight and even safety factors if the actual loads on the mast could be determined. You may even be able to go to a single spreader (if desirable). If you have some ideas on stay and sail loads, we could tackle this problem also.
