Never say die!
Walking Through the Analysis.
- Open the attached spreadsheet “Mast Study HL.xls” (Hand Lay-up)
- Scroll down to Section 4. You’ll note that I’ve now added the metric conversions so you and the rest of the world can work the spreadsheet without abuse. Nominally, you should change the blue items.
- You’ll see I have your proposed 50% larger mast and the Priestess’ (assuming your source) stiffness and strength numbers.
- I have estimated the material density value in (D45). It does not affect the stress analysis, but it does affect the weight estimation. You might want to get an actual material density value.
- I then fiddled with the zero degree ply thickness (D50) until the margins in red were all at least 1.0
- Using Eric’s suggestion about the outside ply, I suggest a laminate of [45b/0b/0u/0b/45b]T
- The subscript “b” is her biaxial weave cloth. I found a representative fabric weight of 5.6 oz/yd^2. Converting to metric and using her 114 mm/ (100gm/m2) conversion, I got a ply thickness of 0.15mm (0.0059”)
- The subscript “u” is her unidirectional material. It needs to be 3.59 mm that we got from the spreadsheet.
- This results in a laminate with 86% zeros. I’ve seen that high in AE applications, but you might want to double check with the priestess and see how she feels about it. If not, see how high she’d go and I can run those numbers.
- I then used an LPT program to calculate stiffness and strength for this proposed laminate.
Modulus = 23.3 GPa (3.38 Msi)
Compression Strength = 383 MPa (55.6 Ksi)
Thickness = 4.19 mm
- The spreadsheet “Mast Study HL2.xls” plugs these numbers back in.
- Note the composite weight is 25% lighter than the aluminum mast. (NOTE: This is the total laminate, but with the estimated density. It is also NOT TAPERED OR WITH CROSS SECTION VARIATIONS). Improvements can still be made.
I want to re-iterate the failure modes and the results of this second spreadsheet.
Compressive Failure – This is where you take a piece of chalk and hit it with a hammer. Things come to pieces. This mode of failure in composites needs to have the priestess’ safety factor (SF) of 5.5. We show a “margin” of 2.12. This means we have a SF 2.12 times whatever the SF already in the aluminum mast. So if the aluminum mast has a 2.6 or higher SF, the composite mast will have at least a 5.5 SF.
Euler Buckling – This is where we take a soda straw and put a finger on each end and press together. Things don’t come to pieces, it just buckles. A composite mast failing this way will bow out and if the load doesn’t let up it will finally break in two… probably near mid span between spreaders. The good thing about this one is it is totally dependent on stiffness and tube geometry. Composite stiffness properties do not vary as badly as strength properties and thus the SF related to stiffness is typically smaller. You might want to get a second opinion on that one. Since the margins are 1.09, we have only a 10% larger SF than the aluminum mast.
Wall Buckling – This is where you take a Fosters’ Oil Can and crush it. If done correctly, it has a nice regular pattern and the top ring is right on top of the bottom ring. The wall on this mast is pretty thin. You have several options. (1) Build a meter long section and crush it and see if it fails like a Fosters or like chalk. Unfortunately, a composite tube failing with wall buckling splinters to pieces like the chalk anyway. The only difference is that if it fails before the 130 tons of theoretical strength, then it failed by wall buckling, if it makes it above 130 tons, its most likely failing in strength. If you actually have some way of applying this much load, you might want to get it strain-gaged. If you don’t have access to the equipment to record strains, you could go the low-tech method. Put a dial indicator between the ends of the meter long mast and video tape the dial indicator and pressure gage on the hydraulics and we can back out load, strength and modulus. If wall buckling is an issue, structure will have to be added somehow. There are many options.
I saw that you want the mast to be hollow. I need to ask, the lines running inside, will they be only rope or will they be cables or have any other metallic items banging away on the inside. I can just imagine cable grinding away the interior plies or metal rings banging away. How many conduits were you planning for the aluminum mast? (One for electrical, one for each line or one for all lines).
Making Decisions
I think you have to decide what your goals are.
- It is lighter (unless local buckling or conduits drive up the weight)
- It is stiffer in bending than the Aluminum mast
- It is stronger than the Aluminum mast. If the SF of the Aluminum mast is at least 2.6 then we are even higher than the Priestess’ 5.5 S.F.
Although, your method of fabrication seems feasible (broken record) I strongly suggest that the zero degree plies must have no waviness. Please consider some way of tensioning the zero degree fibers during cure. Check my post #29 or Stewi’s #32.
Highlights…
- Your circumference is ~1 meter.
- Create a panel 1 meter long and 2 meters wide.
- Stretch the zero degree plies over the 1 meter direction.
- There total thickness of the zero degree plies must be no less than 1.795 mm (1/2 the total)
- Squeegee the hell out of it, but make sure the tension is keeping them absolutely strait. Apply the 0.15mm 0/90 cloth and then the 0.15 mm 45/-45 cloth. Don’t add resin to these two plies. Vacuum bag and let cure while stretching. Bagging while under tension without letting air in will be a challenge. Let the two cloth layers act as bleeder cloth. At the very least, it will improve the fiber volume. See figure 1.
- After curing, cut the panel in half in the zero degree direction.
- Ban saw your mast interior cross section out of foam of say 300 mm long. Bread-slice it into 3 equal pieces. Numbers are Wild *** Guess (WAG) You’ll probably have a far better feel when you feel the bending stiffnes of the laminate. More or less ribs. Thicker or thinner ribs.
- Use the thin-walled PVC pipe for conduit(s) and
- Assemble it like a plane wing… spars, ribs and skins. See figure 2.
- The first panel should be bonded (with the off-axis plies on the inside) to the ribs with the seam clocked around say the 45 degree point. (still need to rationalize this seem some.)
- The second panel should be bonded with the off axis plies outward and the seam 180 degree around.
With this as a baseline, you’ll have a beautiful outside ready to paint and if we need more local buckling strength, we can put a thin (WAG 5 mm) foam core between the panels… That’ totally eliminate any local buckling problems.
