Concrete Barge Design need Help for computation for my Undergrad Thesis
Discussion in 'Boat Design' started by Morileck, Jul 10, 2025.
  1. mitchgrunes
    Likes: 99, Points: 28
    mitchgrunes Senior Member
    These are probably very dumb questions, and I'm not an engineer, but:
    1. Why would you design the home that floats on water in a way similar to the way you would design it on land? Wouldn't it make sense to choose a lighter weight building structure? And maybe one that has a lower cross section to wind and waves?
    2. There is no way this is going to be comparable in cost to a land-based home. And the maintenance issues are going to be much greater. There are good reasons that people who own yachts tend to be very wealthy. Is this really practical?
    Likes: 2,417, Points: 123, Legacy Rep: 2031
    The cost of construction is not only the house itself, but the land. Also, assuming there is land available for sale. There are many floating communities in the world that have been around for a very long time.
    mitchgrunes likes this.
  3. mitchgrunes
    Yes.
    But sometimes there is a cost to using a given floating water location too. I wonder if that applies to the area of interest. And sometimes there are rules against it. Or new rules are created to stop it. I imagine someone trying to build a new floating community in the middle of a river in a national capital, like Washington, D.C. I imagine the U.S. government would step in and force people to leave. Or arrest them for vagrancy. Even if they didn't dump their sewage there.
    I also wonder if a typical architect trained in the building of structures on land would necessarily have the knowledge and legal certifications to build a good structure on the water. Though I have no idea how that applies to the o.p. Perhaps that person does.
  4. bajansailor
    Likes: 1,884, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
  5. Rumars
    Likes: 1,399, Points: 113, Legacy Rep: 39
    Rumars Senior Member
    Because:
    1. Most people want a certain amount of space and light, including space above their heads. They like their walls straight and with 90° corners whenever possible. What they don't want is living in a basement with only one inch between their head and the ceiling, where all furniture has to be custom made to fit curved walls and odd angle corners, etc. Those who can live with such limitations usually just buy any old yacht/ship and call it a houseboat.
    Houseboats are rarely moored in a location experiencing more wind or waves then comparable houses on the shore, there's no need to "beef them up".
    2. The cheapest way to build is using the materials the have the biggest market in the area in question. You deviate only if necessary or if the client wishes an upgrade. The home building market is many many times larger then boat or RV building.
    Waterway use regulations for houseboats are similar to building permits, you can't just put your houseboat anywhere you like, you must insure wastewater management, etc. Yes, there can be fees associated with this, they're similar to building on leased land or property taxes based on square footage. Depending on how exactly the municipality in question handles this it can be way cheaper to pay for mooring space and mobile wastewater management then buying land in the same general location. These regulations also greatly affect the value of the houseboat, since without the mooring rights the floating structure itself has a completely different value. Sometimes what you pay for is actually taking over the mooring lease, and in some cases just like with historic buildings you are married to the existing boat that you bought.
    The building cost structure is the same to structures on land just that foundation and basement work translate into building a pontoon/raft/barge. Exactly like on land the costs and lifespan wary with the clients desire, a few wooden poles under a crawlspace don't compare to a concrete basement just like a plywood box isn't a concrete barge. When compared to building in the same location the houseboats flotation element is usually cheaper overall then the houses foundations because building on a river or canal bank means wet and often instable soil.
    Everything above ground/water stays the same cost wise. Even building material choices translate similarly, if you choose heavy materials like brick for your walls you will need more foundation regardless if it's on land or on water.
    bajansailor likes this.
  6. gonzo
    They do that for tent cities and encampments. It is not an issue only on the water. The OP is not asking about available permits for a particular location. That would be a different thread.
  7. Blueknarr
    Likes: 464, Points: 83
    Blueknarr Senior Member
    This is a very good exercise for a land architect to do.
    Many years ago the owner of a floating home decided to have it remodeled by land based architect and construction company. Nobody consulted a Navel Architect.
    First they marked the existing waterline to determine what was above and below the landline.
    Then removed the interior compartments of the concrete float " because they weren't structurally required ".
    Cut open the exterior walls for windows from the home improvement store. Staying six inches above the previously determined land level.
    Finally a second level was added above. Which brought the water shedding windows to within an inch of the waterline.
    The wind blew.
    Three inch wavelengths, and induced a slight list.
    The windows failed and the house sank.
  8. Adam Salem
    Adam Salem New Member
    Hi , Morileck I have read your posts, I am actually interested in building something similar of your thesis , a river barge that is converted to a house, If you would like to help me in that , I will be very grateful
  9. bajansailor
    @Morileck how is your final year thesis going?
    We have not had any feedback from you since September.
  10. messabout
    Likes: 606, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    I know that architecture students are required to pass examinations for Physics, Strength of materials, Stress analysis, and a bunch of other engineering disciplines. Archimedes principle is one of the most elementary studies and it is one of the first of the basics for designing a land based structure. The matter of soil bearing comes into play. At the Thesis level the architecture student will have mastered all of those disciplines and many more.
    Is it possible that the OP is using the term architect to describe a different academic pursuit such as construction management or other less rigorous pursuit? Language interpretations perhaps.
    Whatever the reality, I wish the OP well.
  11. gonzo
    In what part of the design do you use Archimedes principles on a land based structures? I have designed and built many (I am a general contractor and engineer) and never had the need to.
  12. Rumars
    Where there is a high water table and you have to put a basement under the house. More typical for the US are pools in the same situation, they can easily pop out if empty. These are just two very basic basic examples from residential practice, it can get much more complicated.
    TANSL and montero like this.
  13. messabout
    Here in Florida the soil can become soupy during rainy season or after a major storm......as in Hurricane. Gasoline stations have underground tanks that used to surface themselves when near empty. I believe that the problem is solved by putting a certain amount of water in the tank. The gasoline pickup is arranged so that it lies above the water level.
  14. gonzo
    Empty pools can float. I have been in construction for decades and have never seen a house float away. When the water table is high, leaks are common; floating houses not. In fact, in floods houses may detach from the foundations and float away.
  15. fredrosse
    Likes: 98, Points: 38, Legacy Rep: 56
    fredrosse USACE Steam
    I was involved with concrete boats as a senior mechanical engineering thesis, way back in 1969. We designed and tested to destruction several concrete panels, with many reinforcement arrangements. Two basic configurations were evaluated, 3/4 inch thick (19mm) hull panels for a 33 ft (10 Meter) boat, and 1-1/2 inch thick ( 38 mm ) panels for a 78 ft (25 Meter) workboat. A few years later we built a 30 ft sailboat, and this concrete boat is still in use on the U S west coast.
    Your design challenges are relatively easy to meet all relevant structural and stability design criteria, with hull thickness of about 3 inches, (75mm) more or less. Interior bulkheads, spaced about 6 to 8 ft on centers will provide good structural integrity, multi watertight compartments, and tank storage space for water and fuel, etc. Building similar to a typical spud barge is probably a wise choice. if you want some more technical data, contact me through the website: Beckersville Steam Engineering Co.
    gonzo and bajansailor like this.
    1. Daniel Veraguas
    2. Dong Hyeon Kim
    3. Ali Golshani
    4. mustafaumu sarac
    5. Magus
    6. mtumut
    7. mtumut
    8. mustafaumut
    9. Will Fraser
    10. lewisboats
