Hello,
I am a new member here ! Glad to read all the fantastic info in all the threads !
I have spent a lot of free time over the last year, restoring an older 15m Chinese Teak Cruiser. Truly a labour of love with this vessel.
Now that the hull has been restored (and all the termites dead). It is time to begin the Electrics... I have a clean slate here, and I want to go "Over-the-top" with this. Put all the convenient switches, panel lights, Renewable energy sources, and monitoring.
I have 2 births that the old girl can get tucked into, and both have a 32 amp (230v 50Hz) service. The vessel came with an older Onan 7.5Kw 230v 50Hz generator. I have a few solar panels temporarily installed on the top deck that will move to a permanent rack above the top Bimini. I want to also add 2 wind turbines on the stern of the top deck (they are 600w each).
I hope I could get some positive input from the forum on what I am currently doing on the AC electrics, as well as the DC side once the AC is completed.
One thing that I have always wanted to do, was to have a kWh metre to know exactly what I am using. So many times I have done the math about how much each device uses (fridge, charger etc.), but the real world is never the same as what looks good on paper. I found a factory that makes nice panel mount kWh metres that I am incorporating to the AC panel, and since I will have Solar and wind, I will install 2Kw grid tied inverter to feed back to the grid when she is sitting silent at the birth hooked up to shore power... another great use for the kWh metre showing what I send back to the marina (love to lower my power bills from the marina HaHaHa).
These are the type of creative things I hope the forum can suggest, to help me make this Teak Vessel very special and modern !
I am putting the AC panel together now. What you see in the attached picture is the layout for the AC Main, and the Inverter AC panel. Still at a point to make some changes to make it better !
Attached are some images of the AC main panel, as well as the Inverter AC panel.
Thanks,
Alan
Thanks,
Alan
