IF you want to build the ultimate class boat you need to learn about sailing, the class, sail and rig design, and than hull design. I think the best way to learn about boat design is to go out and sail in as many different similar sized boats you can, and study their hulls and rigging, it is also a lot of fun. Go hang out at sailing clubs and bum rides, rent or borrow as many different sail boats in the size class you can. Get to know other racers and serious hobby sailors, go out with them and compare their hulls, sail plans and rigs and how they behave differently. Also gather their opinions (do not put too much stock in that, but it can be useful to know what others are thinking and doing in the class).
This will give you a feel for how the different sizes and shapes affect the performance. the hull is only one part of the system, and not even the most complicated part. The sail plan, rigging and other parts of the system will likely give you far more trouble than the hull. And the single biggest factor, you own sailing skills, will be developing along the way. You have to understand, and have a feel for, seamanship and how all the various components work together before you can know what the optimum design will be.
Also, it would save you a lot of time and money in materials, for your first one, to just buy a set of current Cherub plans (if you can find any), and built that one first as your baseline. Or go buy a used boat. Than go out and use it a lot and learn it. Than you can use that hull as your "mule" to test out various rigs, sails, centerboards and rudders, and alterations to the hull design (caution: make only one change at a time or will not know what works and what does not). After a number of seasons of messing around with what is known to work, than you will be ready to experiment and design the ultimate hull. Not likely it will work the way you expect on the first one (no matter how much fancy computer analysis you do on it), so expect to evolve a new design, learning as you go. It always works out this way, I like experimenting too, but I have come to expect to build two or three examples before I am happy with it.
If this sounds like too much work, than just buy a competitive boat and enjoy using it. Going off in "innovative" directions without a good understanding of what you are facing is just a waste of time and very disappointing, you will just end up giving up on it after investing a lot of time, money and materials. So I suggest first study, participate, learn and understand what works good now, and than try to improve it from there.
Good luck, it looks like a fun class that allows experimentation (unlike a lot of class sailing rules). Keep us updated on your progress.
