mitchgrunes
Senior Member
- Joined
- Jul 10, 2020
- Posts
- 343
- Reaction score
- 100
- Location
- Maryland
What I'm taking away from this discussion is that skin-on-frame prototypes are the easiest, cheapest and fastest to modify, in terms of shape - provided you use a skin that stretches or can be pulled tight over the frame, and you use a construction technique that allows shape modification. But also that SOF limits the final shape, and that if I were a hard-core competitive athlete, it wouldn't be completely optimal - which I can live with.
If I'm wrong about those things, please tell me.
In most sports, a lot of people benefit from and use custom made or adapted sports equipment, because it interacts with your body in very individual ways. Also, your equipment lets you express your individuality, and in aesthetic competitive sports, helps you stand out from your peers.
Naval ship and commercial ship designs are presumably different. The crew and components need to be replaceable and somewhat interchangeable, so customization is counterproductive.
In the long term, I like the idea of a surf ski/kayak hybrid. The surf ski phase would be easy to launch quickly from and land from in breaking waves, which have a tendency to swamp closed deck kayaks, which can only be partially compensated for by compartments, airbags and sea socks. (I've never used a sea sock. I suspect they are difficult to enter quickly, in surf.) An custom built surf ski would not hold much water while I was in it, and would mostly drain after each wave. I would lips to tuck my knees under. Past the breakers I would zip up the fabric and mount the spray skirt to gain the advantages of a closed deck kayak. A deck pump could pump out the rest of the water. I'd love a fold-up or break-apart design that can be stored out of the sun and bugs, in my home, and need not create roof clearance problems in parking garages, so I might eventually look into aluminum tubing. I'm also tempted, in the long run, to sew, nail or glue a more durable material into the keel, to launch from and land at gravel beaches. Something cheaply replaceable, like vinyl flooring, or veneer. (My best guess is that thick single-sheet materials, like vinyl flooring or veneer, can't be shaped into decent 3D boat designs?? If so, too bad. Vinyl flooring is CHEAP, if heavy.)
