sdowney717
- Nov 13, 2010
- 1,600
- 118
- Newport News VA
I think they are Michigan wheels, typical left and right hand rotation.
I am including from the boat manual the page for the props, which seems all over the place and very generic.
My 22 by 20 props have about 2 inch tip to hull clearance
Boat is 20,000 lbs, Semidisplacement style hull, Velvet Drive 72c with 2.91 to 1 gear reduction, 1 3/8 shafts, twin engines 265 HP each
Engines can not barely get to 3000 rpm.
Boat is slow, typically cant get past 8 knots. It sure can pull weight though at slow speeds.
I saw an Eggharbor boat brochure once, and it said top speed around low 20's knots, so it should do better
So any opinions on the props. Manual says props need to allow for 3600 to 4000 rpm.
Propeller page, notice top speed column, my engines are M-392.
Seems odd set of info here for props.
