BlueBell
. . . _ _ _ . . . _ _ _
- Joined
- May 7, 2017
- Messages
- 3,426
- Reaction score
- 1,308
- Location
- Victoria BC Canada
Wondering if you may be able to help some Boy Scouts with some prop size options for the following set-up.
-500 watt electric motor 75% efficiency rating, 465RPM loaded.
-6 knot advance
-200 watt input from solar panels only
-400 watt input from battery only
In the battery only endurance heat we must last 25 minutes to go the furthest distance.
We've calculated a 400 watt throttle setting should last 28 minutes.
If we approach the LVC of 30V, we can throttle back to be sure we last the 25 minutes.
Boat weight ~60kg (135 lbs)
For the two sprint heats, we want to go as fast as possible for ~45 seconds on the panels alone.
Boat weight 85kg ( 185 lbs)
We are interested in testing half immersion props as well as full immersion.
The motor is mounted on a swivel with a five foot prop shaft like a Thia long-boat.
Thank you
-6 knot advance
Thank you
