Can anyone answer my original question on how to calculate the strength of the lower lip of an angle iron?
Fallguy,
The beam that you have built using 1/4 inch by 2 x 2 angle forming a T is an extremely poor profile as far as minimizing the amount of deflection at the center point of the beam for the amount/weight of material that you have used.
This 88 inch 'beam' will weigh over 50 pounds.
This is all a basic overview AND by basic I will not get into a bunch of equations or units, ie inches to the 4th, or inches to the 3rd etc, as the discussion will get complex
If you take a piece of wood with measurements of 2 inches by 6 inches. If we orient the 6 inches vertically, and apply a load in the middle, it will deflect less than if you orient the 2 inch vertically and apply the
same load. So for the same weight of material, you minimize deflection just due to the orientation of the wood. There is a neutral axis in a symmetrical cross section that is midpoint between the edges. The further that you have material away
from the neutral axis, the lower the STRESS which results in less deflection. With an unsymmetrical cross section, ie either one piece of angle or two pieces made into a "T", the neutral axis is closer to the horizontal flange.
So if the distance from the neutral axis is smaller, you will have more deflection
You have made the assumption that you need to calculate the "strength" of the lower lip.
Assume for a moment, a beam with no deflection or at least an extremely small deflection. The end points of the beam, bolted to the 1.125 angle, would provide a 750 pound load, vertically down, ie shear only. At the end points
of the beam there will virtually no moment forces producing moment stresses. (Vb excepted) So taking your .125 inch leg x 4 inches long, your shear stress at the cantilevered leg is about 1,500 psi, much below the shear strength of the material.
Will there be some induced bending moment? A bit but due only to the deflection of the beam. We know intuitively that when the center deflects downward, that it will curve toward the end points and try to pull the lip downward.
But will it? While the lip of the 1.125 inch angle is only .125 inch thick, it will be bolted to the 1/4 inch beam angle making the horizontal thickness .125 + .250 or 3/8 of an inch thick PLUS it is also has a 2 inch by 1/2 inch vertical flange
from the 2 inch by 1/4 inch angle times 2.
So long as the bolts will carry shear flow loads and minimal loads due to the beam deflecting, you do not have to be concerned with the lip "bending and causing issues"
Another issue here is that the type of end conditions, ie where the beam attaches to the wall/structure impacts the deflection. And this imposes some guess work as the 1.25 inch angle is bolted to say plywood whose strength is
significantly below steel. If your 1.25 angle was welded to a solid steel backing then you can assume loads corresponding stresses and deflection would produce call it "A" series of values. If you assume the end conditions to
be simple end conditions, the you will have different values for loads, stresses, deflection. Call it "B" series of values. As the plywood backing attachment will offer some rigidity to the 1.25 angle, AND if you could determine
some percentage of the how to allocate the portions, I would expect that the load, stress, deflection calculations would be somewhere between the "A" series of values and the "B" series of values
That being said.
I have never ran across any calculations that would specifically show leg deflection due to loading as you are looking for.
I am only guessing here in that you have made an assumption that the 1.25 leg will act as a pure cantilever beam and that this leg will fail due to loading. Not taking into consideration that the beam bolted to the 1.25 angle
will stiffen the lip of the smaller angle.
IF your calculations are correct and there is a 5/8 inch deflection without a FS, the leg "downward bend" will be limited by the stiffness of the main beam.
So we are back to the main beam poor design, or usage of material and possible issues with the 1.25 angle attachment to the plywood being able to carry the required loads without the plywood deflection
So as a summary
The smaller angle lip will support the shear forces but will be limited by the attachment of it to the plywood
The lip will not act as a cantilevered beam due to the bolt connection
If I understand it from the discussions, you will have a panel that will drop in to the pocket and this will carry some of the load. It pretty much has to or your 52 inch span between your three beams, is excessive.
If I had started this from scratch with an unhampered budget, I would have had an unequal angle formed to attach to the plywood. say 3 inches by 1 1/2 inch legs 3/16 inch thick. The 3 inch leg going
against the plywood and 2 rows of bolts/screws *** for attachment. The beam would have been of a taller height which would have made the beam lighter, ( getting material away from the neutral axis) and minimized
the deflection.
*** a single row of attachment bolts will permit the angle to wobble along the axis of the bolts. If you create two parallel lines you limit this type of situation which could result in failure over many loading cycles
