Flying Fin
I'm in the process of installing a 85 ford diesel in place of 330 mercruiser buckled up to borg warner on a old Bravo outdrive. Has anyone done this conversion. I'm looking for updated sorce for marine manifolds, bell housing,flex or drive plate. I'm well versed in CFR , ABYC, ABS,.Looking for info on what effect deleting vacum pump has on high pressure pump operation and adjustments.How much restriction on injector return line,any problems with using manual control on glow plug operation in lieu of auto . Plan on using existing Raw water pump and Heat exchanger, not sure if present heat exchanger has enough cooling capacity. Not sure at this time how I'm going to route exhaust and cooling water overboard. Any info ya'll have would be welcomed. Flying Finn
