ambarcatiuni
  1. strip planking+cold molded hull
    we over-built? this Pilot Cutter 32 ft LOD hull in routered strip planking to 2 1/2". Douglas fir under LWL; and White Spruce topsides; barbed bronze nails fastened ; glued in West System epoxy + three layersx3mm mahogany veneer.
  2. 32 ft Lyle Hess design  Bristol Channel  Pilot Cutter
    Pilot Cutter epoxy strip planking and cold molded; was built in Institutul de Ape Bucharest Romania 1999; for American Randy willard.Rudder laminated. Spars were laminated in white spruce.No engine was installed.fastenings siliconic bronze.Bulwarks cold molded mahogany.
  3. teak cockpit settees
    the deck and cockpit are sandwich teak/epoxy/pvc foam; cockpit backrest in laminated mahogany. the glass sheating method proved quite labor&materials intensive.
  4. laminated keel
    laminated keel
    keel and stems are oak laminated bottom hull 3 layers biaxial fiberglass set in epoxy reinforced by laminated massive longitudinal stringers. floors laminated double direction
  5. X-plore22
    X-plore22
  6. X-plore cold molded mahogany deck over fiberglass composite hull
  7. Melkorka at Christmas
  8. pilot cutter
    pilot cutter
    http://www.yacht.ro
  9. Black Sea Cruiser interior
    Clear coated Mahogany cabin sole; mahogany tops and sides berths ; Moonlight opening ports; Stainless hardware teak@epoxy louvered door at forward bathroom compartment
  10. Black Sea Cruiser mahogany cabinets
    it was before the advent of digital camera revolution. I designed the interior of this boat in a classic style. Looking aft through companionway doors made in teak (center); on both sides mahogany louvered doors cabinets; wich on the other side of the bulkhead act as consoles.
  11. bridge deck
    bridge deck
    mahogany top charts&cofee desk teak louvered doors and hatch composite console portside sliding cold molded lateral windows opening front windows mahogany
  12. bathroom console
    bathroom console
    I designed twin consoles into the bathroom at the forward section of the hull ; supporting the sink and acting as an extension of the bed on the cabin side of the bulkhead. the bulkhead is as well reinforcing the cabin. in order to make better use of the space at the companionway area I...
  13. clear coated teak hatch
    companionway teak louvered doors customised, opening dashboard opening front windows stainless hardware details http://www.yacht.ro
  14. rounded stern&cockpit area
  15. Classic Racer Restoration
    after 2 years and 3 months the old racer is back on water. new cold molded hull and new dynel&epoxy deck; plus all steel framing and fastenings changed with laminated framing bze fasteings this was the first total rebuild and restauration ever performed arround here aceasta a fost...
  16. Nuvola Rossa's Restoration
    Nuvola Rossa's restoration was as well a first; the first rebuild of a classic mahogany ronabout performed in Romania
  17. Nuvola Rossa
    Nuvola Rossa
    the framing was rebuilt in laminated wood; old rotten bottom was changed with new cold molded bottom in plywood&epoxy; the 200 hp chris craft engine was rebuilt. we as well did the re-varnishing and repainting; rechroming of all hardware
  18. Restoration Nuvola Rossa
    this restoration of a Riva craft was a first in Romania
  19. classic Camper&Nicholsons sloop restoration
    Andrew Thomas
  20. classic racer restoration
    deck was rebuilt by taking off the weakened plywood on fastenings rows upon the beams,and scarfing in new plywood; adding a cold moulded solid wood sheer strake, adding a solid wood&epoxy forward section, and reinforced by dynel&epoxy.all steel deck as well as hull fastenings were...
Back
