XFoil
Discussion in 'Boat Design' started by dalebirrell, Jan 10, 2010.
  1. dalebirrell
    Likes: 1, Points: 0, Legacy Rep: 32
    dalebirrell Junior Member
    Is anyone familiar with the lastest Xfoil program?
    I was having issues loading some NACA sections. I opened a 63412 fine, then next time i ran the program i get an error message when trying to open the same foil again...?
  2. wet feet
    Likes: 448, Points: 83, Legacy Rep: 124
    wet feet Senior Member
    I have to admit finding Xfoil a bit challenging.So I shelled out ten euros for Profili which I have found rather more comprehensible.As I understand it the same processes run behind a fairly easily navigated interface.
  3. tspeer
    Likes: 303, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    Did you upgrade XFOIL versions in between?
    Check the file for tabs and replace them with spaces. You probably did this on the original file, but maybe you've saved the coordinates from a spreadsheet and didn't use the exact same file as before.
  4. Guest625101138
  5. dalebirrell
    thanks guys, appreciated
