Hi
This is my firts post at this forum. but I have read quite many of the treads about XFoil and foils.
Now I have a question about how to calculate the Re number in XFoil. If I use the normal formula Re=v/V for water at 20deg, I end up with Re=2.5e6 for a boat speed of 5 knots. Many treads are talking about Re in the range of 0.2e6 to 0.6e6 for a "normall" keel monohull. This value is 4-10 times smaller what I expect it to be. Any comments on this?
The other question is the value of NCrit. The default value is 9, but most recomendations says 3 for water tank like conditions. What about normal dirty lake water?
I have seen that the typical behaviour (CL/CD behaviour) of a foil at NCrit of 3 and 9 makes the Re value to be changed a factor of 5-10 e.g NCrit=3 and Re=75.000 has the same typical foil behaviour as NCrit=9 and Re=750.00 (with an offset on Cd).
Are there any other parameters that should be adapted to reflect water fluid instead of air in XFoil?
/Fredrik
/Fredrik
