Where is this?
Discussion in 'All Things Boats & Boating' started by Wynand N, Apr 22, 2007.
  1. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    you could say that yes but you'd be wrong
  2. hoytedow
    That narrows it down ever so slightly.
  3. wardd
    wardd Senior Member
    as edison said, he learned another way not to make a light bulb
  4. Angélique
    Here's a wider vieuw . . . wider vieuw.jpg . . . that might be a clue . . . :cool:
    Good Luck!
    Angel
  5. TeddyDiver
    Likes: 150, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
  6. TeddyDiver
    Had a feeling that I've seen the picture before here but wasn't quite sure. However after solved it found the previous posting by Richard too http://www.boatdesign.net/forums/open-discussion/where-17014-200.html
    After hundreds of quests it's unavoidable we'll pump in to same places occasionally.. a list of solved quests could be usefull..
  7. TeddyDiver
    A new one.. it's me walking down in this dry place. Thou it's dry it ends by the sea, and was an important route of a defeated army ones.. Name of the valley?
      File size:
      806 KB
  8. Angélique
    I PM'ed the answer to Wardd and he asked ‘‘how did you guess?’’. Now Teddy has it I might answer here instead of PM. When I saw the pic I knew I had seen that pier before on a pic from that angle. While doing other things a thought of Pitcairn came out of the blue and I knew it was because of the pic and also knew I had seen it here. Richard has posted exact the same pic on december 7th 2009 in post #2999 on page 200 as Teddy linked. It might be an idea to use the ‘‘Search this Thread’’ buttton before posting a new teaser. I didn't do that before but will in future . . ;)
    Thanks Wardd..!!
    And Teddy thanks for the new one . . :)
    Cheers!
    Angel
  9. Angélique
    There is a ‘‘Search this Thread’’ button above, just below the page nrs. It works quite well.
    click ‘‘Search this Thread’’ ---> enter keyword ---> click ‘‘Go’’ ---> click ‘‘first line of a post’’ will lead to that post. (click ‘‘thread title’’ will lead to the first page of the thread)
    Just try the name there before you put the quest on.
    Not the ‘‘Search’’ button which is just above the page nrs. That's is to search the whole forum.
    Good Luck!
    Angel
  10. Angélique
    Looks like Spain east coast . . . . . ? ?
    Cheers,
    Angel
  11. TeddyDiver
    Right part of the world (Med) but wrong country :)
  12. latestarter
    Likes: 54, Points: 28, Legacy Rep: 233
    latestarter Senior Member
  13. TeddyDiver
    Right country.. now it should be a piece of cake:D
  14. hoytedow
    Thank goodness I'm going senile! Even the old places look new to me. Thanks, Teddy for linking to the old clues. :D
  15. mreoe4sure
    Likes: 3, Points: 3, Legacy Rep: 32
    mreoe4sure who me
    Is it the vale of tempe ? steve
