what type of window glass is best?
Discussion in 'Materials' started by about time1, Feb 22, 2015.
  1. about time1
    about time1 New Member
    need to replace the glass window in a 1980 46 post sportfish. This is a salon window. What kind of glass should I be looking at?
  2. rasorinc
    rasorinc Senior Member
    I'm researching the idea of a double layer of auto windshield class with a single layer of 3-M
    reflective coating tape maybe colored between the 2. Also considering to have the inner glass layer to have a wire grid (wire glass ) This is for the windshield.
  3. gonzo
    Likes: 2,266, Points: 123, Legacy Rep: 2031
    Most likely it is tempered/toughened glass.
  4. JSL
    JSL Senior Member
    As per Gonzo - tempered or toughened.
  5. PAR
    Tempered glass is what is commonly used, though I often use laminated glass instead. Laminated glass isn't as strong, but is safer and is available in standardized tints (as well as clear). A ballistic film (3M is the best) will make tempered glass much like laminated glass, in that it will remain intact if cracked or broken. Additionally, the 3M ballistic films (only available and applied by 3M) can be had with various tints, some remove 98% of UV A and B, so varnish and fabrics don't age. My house has this 3M film on every window, which isn't cheap (over $3K ten years ago, but also on 31 windows), but it's great stuff and much better then the over the counter stuff you can get at an automotive detail shop.
  6. about time1
    So tempered glass, cool thank you. Will a suggestion be made for sealant, or should I say bedding? Did not like sitex, did not stick to the glass. 95% confident on my prep with roughing it up and primer. I was able to peel it off the glass with my fingernail after about 3 months, then the window leaked.
  7. DCockey
    Likes: 677, Points: 113, Legacy Rep: 1485
    DCockey Participant
    Laminated glass transmits less noise than tempered glass of the same thickness.
    DogCavalry likes this.
  8. rasorinc
    Call a windshield replacement company and ask them what adhesive they use to reset a new front windshield.
  9. Eric Sponberg
    Eric Sponberg Senior Member
    About Time 1: Welcome to the forum. Tempered glass is about 10 times stronger (literally) than laminated glass. Unfortunately, when tempered glass breaks, it shatters into thousands of pieces (literally) and broken shards of glass shoot all over everything, scaring it (furniture, walls, floors, human flesh, everything) in a very devastating way. Laminated glass, on the other hand, will shatter, but stay intact in the frame, because of the fabric layer between the layers of glass--which is why they call it laminated glass. With laminated glass, on breaking, You won't get any little shards of glass flying through the air--zero, zip, nada. Chemically strengthened laminated glass is about twice as strong as unstrengthened laminate glass,. and so only a fifth the strength of tempered glass. For boats, I almost always specify laminated glass, principally for it shatter resistance.
    I hope that helps.
    Eric
  10. DCockey
    DCockey Participant
    Also my understanding is laminated glass is cut and then used, while tempered glass is cut before tempering, and then sent to be tempered.
    All automobiles sold in US and Canada have had laminated windshields since around 1930. Almost all side window and rear window (backlite in auto industry terminology) has been tempered. The major exception is some luxury cars with laminated side window glass for sound transmission reduction.
  11. SukiSolo
    SukiSolo Senior Member
    With respect David, I think you meant laminated glass is cut and used. It is certainly available from glazing outlets in the UK for domestic doors etc where regulations require it.
    One vehicle that used all flat sheets of glass (laminated) was the Citroen 2CV, partly to make it cheap to repair any screen that was broken. Any glazier could cut suitable stock to a pattern.
  12. JSL
    JSL Senior Member
    One small point when doing windows fitted in the navigation area & wheelhouse. You do not want to compromise visibility so avoid tinted windows or go with a very light tint if you absolutely must. Tinted windows can also 'shift' the colors leading to a 'ColRegs' moment.
  13. baeckmo
    Likes: 836, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Have used polycarbonate with glassed surface for windows in workboats, including rescue and fifi. Accepted by DNV and Swedish marine authority, easy to work with, has low heat conductivity (less condensing in chilly environment), and takes tremendous physical loads without shattering, provided the framing is ok.
  14. DCockey
    DCockey Participant
    Any idea of the cost of polycarbonate with glass surfaces compared to tempered glass and laminated glass?
  15. Jim Caldwell
    Likes: 8, Points: 18, Legacy Rep: 48
    Jim Caldwell Senior Member
    And the difference in UV resistance!
