What type of adhesive to use with Divinycell H100
Joined
Feb 13, 2022
Messages
3
Reaction score
Location
new jersey
Little unconventional. I am not building a boat, I'm building a small car. I hope you can still help me. I am planning to use Divinycell H100 to build the chassis and I am wondering what type of adhesive to use to glue the pieces together. I hope this is allowed. Thank you.
Epoxy. Raw epoxy precoat and final thickened epoxy with 1/16" vee trowel both sides with optimal joins of 1mm. Thickener is typically fumed silica.
But this won't be strong enough alone for a car chassis; so this is not a structural schedule for laminating glass to the core, etc.
You can also buy products like gelmagic. https://www.systemthree.com/products/silvertip-gelmagic-non-sagging-epoxy-adhesive
But important to note you need to test components to meet your structural requirements. Not for me to give you qa standards.
Raw foam cores are not very strong.
6061 Aluminum has shear strength of about 30,000 psi. Raw h100 is about 205 psi. So, it is important to note when discussing laminating advice when such a massive discrepancy between cores presents. The products are about 150 times different and shear would be critical in auto accidents.
I accept no liability here. Just pointing out fair concerns when being helpful. The bond strength of epoxy is often noted in generic, untested terms of 2000 psi, which is also 15 times less than aluminum.
If you are using the H100 as core, you can bond it with epoxy as its shear strength is greater than H100. Corebond will do.
If you are using the core as an element of a design, such as a beam, you insert laminate in between. Usually when the depth to width ratio of the beam exceeds more than 1. This is because tall I beams are not stable when side loads are present, i.e. torsion.
... This is because tall I beams are not stable when side loads are present, i.e. torsion.
For an I-beam, you show, that's correct.
But if it is a 'box' shape section, that's different. It has torsional stiffness and a shear flow area:
Where T=2.A.q..... A being the enclosed area of the closed cell - shown in black
You only need to check the webs for buckling, and shear under the load...
How do you determine the schedule for the laminate between the cores?
That would depend on a lot of factors. Are you just duplicating the shape if the old chassis and making glass over foam core core? Are you using hand layup epoxy?
You haven't given us much information or drawing.
This might give you an idea so that we are in the same page.
I attached the drawing for the ibeams for my boat. I think I misunderstood the drawing you provided. Ed just calls for csm between the layers of foam. Since I'm using epoxy would a layer of 6 or 8 oz cloth suffice?
Ok. Now we are on another page. I thought there is a similarity to OP's thread.
When building up core foams, gluing it together is a practical idea. You don't need to increase shear by adding shear ties. There are several ways. Corebond (polymer type), epoxy mixed with microbaloons to form a slurry (coat both sides then trowel), or a light CSM of about 280 gr/m2 or less will do. with the exception of 1 and 2, it is a good idea to "hot coat" both surface with a light coat of epoxy to ensure max bond since some foam surfaces are rough.
My mistake I misunderstood. Sorry to hijack the thread.
Scuff. That is OK. Seems similar. I reserve the mat interface for high density cores because I need high shear strength. Unfortunately, low density core surface is so rough, I have to use micro slurry to have a good bond.
