What is this?
Discussion in 'Fiberglass and Composite Boat Building' started by Vendy, Sep 2, 2022.
  1. Vendy
    Vendy Junior Member
    Hi guys ,
    i saw this video on the internet.
    And just wondering what is this ? And what it is for ? they applied those coat after gelcoat?
    Fyi , infusion lamination .
  2. fallguy
    Likes: 1,700, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    My guess is a pilothouse top.
  3. jehardiman
    Likes: 1,177, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    To me it looks more like a hull liner...but we digress...
    Context is everything. Could you point to the video URL? I assume you are talking about the black compound... Is it over the gelcoat but before the lamination, or after the lamination?
    fallguy likes this.
  4. Vendy
    Vendy Junior Member
    Unfortunately I don't really have the video .
    Yeah the compound i was wondering what was that
    It's after gelcoat before lamination ?
    My concern is: what kind of coat was that? thanks
  5. Vendy
    Vendy Junior Member
    I mean after the gelcoat. Before lamination
  6. jehardiman
    Then probably a barrier coat to reduce print through and improve osmotic blistering resistance.
    KD8NPB likes this.
  7. Vendy
    Vendy Junior Member
    If it is a barrier coat ? Do they need to do the tie layer (chop gun/ hand layup) ?
    Or they can start laying up the glass (prep for infusion) ?
  8. Blueknarr
    Likes: 420, Points: 83
    Blueknarr Senior Member
    Barrier coat would also prevent infusion resin from attacking the gel coat.
    Could go directly to infusion.
    Might need mat layer.
    Might include mat in infusion.
    Depending on resin systems used.
    fallguy and jehardiman like this.
  9. Vendy
    Vendy Junior Member
    so
    Gelcoat - barrier coat - laying up glass (include CSM)
    What happen if it without CSM ?
  10. fallguy
    Probably print through..
  11. KD8NPB
    Likes: 39, Points: 28
    KD8NPB Senior Member
    It’s possible to direct infuse on barrier coat.
    skin coat is recommended though.
    best profile;
    Gelcoat
    Barrier coat
    Mod VE skin coat
    Mod VE skin coat (again)
    Infuse
  12. Vendy
    Vendy Junior Member
    thanks for the information.
    So I can do it
    Gelcoat - barrier coat- infuse
    what will happens if no skin coat ?
  13. gonzo
    Likes: 1,731, Points: 123, Legacy Rep: 2031
    Sometimes a dark gelcoat is sprayed inside of the exterior light color to prevent translucence.
    redreuben likes this.
  14. KD8NPB
    Prerelease of the gelcoat is the biggest risk.
    It will be difficult to attain a Class A gelcoat finish off the mold because of the exothermic temperatures of trying to apply a large quantity of material in one go.
    Vendy likes this.
