I do not write off the Wharran wingsail, simply there is a proven since many years solution, used from windsurfs to racers around the world maxi trimarans. So you have plenty of sail makers having experience with these sails, which is simpler than the Wharram.
I do not see the interest of starting an experimentation of a custom sail plan on a small boat not made for racing, when you have already a proven solution which works well which has been refined for years. The Minis (6.5 meters monohulls) cross the Atlantic at 6.5 knots mean speed solitary, with no assistance nor routers...A racing mini is able of more than 18 knots, and can keep in optimal conditions 16 knots during hours, as seen last year crossing the Channel, and the cruising ones are not far behind.
A friend of mine has since 2016 a Revolution 29. It's a comfortable rather heavy (5.5 tons) sweet cruising boat with a round bow and enormous volume, it's easy to maneuver alone or best for 2 persons who are not athletes. It's a family boat.
But that takes 12 knots easily without efforts with dacron sails, and you keep 10 knots while sipping your Chassagne Montrachet. It's able of 16.5 knots top speed with 25 knots of wind.
The mainsail is very well mannered, rather easy to tune and easy to control. There no complication with running stays. Brief that works nicely for relaxed cruising. The mast when tuned needs only regular maintenance like any mast. That lasts many and many years.
The problem for a free standing mast is that sail is not triangular or even rounded headed like on a old beach catamaran, the rectangular sail is very powerful with a pretty high center of effort (that explains the unusual 2 pairs of spreaders on a 5.5 tons 29 feet to keep the mast straight). If you want the same surface of sail ie performances of a Revolution 29 on a lone free standing mast you'll have a serious engineering problem on a small 30 feet.
Aluminum has a drawback for free standing masts; fatigue. Fact well known since ages.
So it's better to use a material which has not this drawback. There are 2 contenders: wood and carbon fiber. Wood will be too heavy for the stability of the boat, remains the carbon fiber. Pretty expensive specially on a custom mast for not a sure result. And it will remain too heavy for a 30 feet with so much sail.
The normal bending of the free standing mast will spill out the wind at the head of the rectangular sail which requires a mast as straight as possible. It's finally a useless complication.
The Wharram is a catamaran so with such a width you can have stays without the need of spreaders. That's impossible on a monohull lacking of width, as the angle of the stays is too small.
Simply rectangular sails always needing a straight mast for working are not compatible with free standing masts unless countless complications.
So it's better to stay with a proven solution when you won't name your boat "Regardless of cost" or "Experimental". Mistakes are costly.
Have a look at the pics of the 29 feet, look well at the rigging, sails and hardware and tell to me if you see anything complicated or unusually expensive on this 29 feet. Personally I see a rational system, rather low cost using ordinary materials, nothing fancy. No backstay, no adjustable or running stay, so the mast won't fall because of a mistake while tacking. A simple block on a normal track to control the main sail, a boom vang, 3 winches, 2 for the front sails, one all purpose. It's minimal.
Accueil - Afep Marine https://www.afep-marine.com/revolution29-bateau-aluminium-photos.php
