West System fast set (205) Epoxy set-up failure
Discussion in 'Materials' started by SpiritWolf15x, Nov 26, 2012.
  1. SpiritWolf15x
    Likes: 1, Points: 18, Legacy Rep: 15
    SpiritWolf15x Senior Member
    Alright, thanks all.
  2. tunnels
    tunnels Previous Member
    What were you thinking ??
    I cant post what i had wriiten and just deleted !:!:
  3. waikikin
    waikikin Senior Member
    Seen a similar thing once, wrong pack sizes turned up, assumption made on which was base/hardener & a big day of mixing resin & microballoons - one side of a 50 footer with a beautiful screed of delicious chocalate coloured filler applied, set up........ like rubber, wouldn't sand, wouldn't wash, poor bugger had to carve the lot off with a keen chisel about a 1/2 inch cut at a time. Great lesson in reading instructions & specifications to become familiar with the particular product.
  4. PAR
    We've all done this at some point, it happens, you learn, become more anal about mixing ratios and move on. Yep, it sucks, but you had to learn some how. Scrape, cuss, then sand, cuss some more and eventually, you'll have this lesson well ingrained into your memory.
  5. BMcF
    Likes: 226, Points: 63, Legacy Rep: 361
    BMcF Senior Member
    Never.
    Don't ask me how I know that. :rolleyes:
  6. Herman
    Herman Senior Member
    I worked for the West System distributor in NL. Sometimes you have a lot of fun talking to people on the phone:
    -my epoxy does not cure
    -did you mix in the right ratio?
    -mix with what? You mean I also should use the small container?
    or
    -your epoxy cured before I was able to use it
    -what did you do exactly?
    -I mixed your 30 kg (some 70 lbs) pack, then poured it into the boat, and start rolling it upwards, to coat the wood.
    or
    -what solutions do you have to removed cured epoxy?
    -on what surface is the epoxy, and how much?
    -it is on the carpet in the living room, some 2 kgs...
