Hi all, Newbie to the group. I need some brain power sent my way. I have a 1998 19' Stingray boat with a 4.3 Thunderbolt Mercruiser.
I pulled the drain plugs in the fall and turned it over to make sure there was no water left in the engine. I took it to the lake for the first time this year last week. I started it before I left my driveway, it acted like it was flooded but it came around, I figured old gas, although I always use Stabil.
Launched the boat, fired right up. I took off and it sputtered a couple times and then took off running great. Went to an island on the lake and it died as I pulled ashore. I took the distributor cap off and it had a lot of moisture in it. Dried it out and cleaned it and it fired right up. Took off down the lake (towards the ramp) I ain't no dummy. Pulled into a cove under low rpm and it died, tried to start it and the starter went out.
So I get the starter rebuilt and put it in, it won't turn over. I have built a few Chevy V8s from scratch. When an engine won't turn over there are only a few things causing it. I pulled the plugs and water in both banks. I know the chance of Both head gaskets blowing out is highly unlikely. A cracked block into both banks of cylinders?
Is there any way the intake manifold gasket can leak into both banks?
I am sorry about this being so long, but I figure the more info I give you the better chance of you being able to help me. Thanks in advance.
