Waste water management
Discussion in 'Boat Design' started by kaankarli, Oct 12, 2015.
  1. kaankarli
    kaankarli Junior Member
    Hi all,
    For the areas where treated waste water cannot be discharged; would you prefer to run the treatment system and store treated water in the holding tanks or store it untreated for a later treatment?
    Please consider that there is another tank before the treatment unit where waste water already runs into after vacuum system. and above mentioned holding tanks are specialy installed for extra capacity.
    ps. by local law even if treated you cannot discharge anything around Turkish waters.
    Thanks,
    KK
    Likes: 1,491, Points: 123, Legacy Rep: 2031
    Treated water will not produce bad smells. Sometimes it is simply treated with chlorine.
