Vinylester resin
Discussion in 'Fiberglass and Composite Boat Building' started by Mcdo2137, Oct 8, 2023.
  1. Mcdo2137
    Mcdo2137 Junior Member
    Does VE require csm matt between plywood core and transom skin or is thickened resin sufficient? Between plys of plywood also?
  2. ondarvr
    Likes: 779, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    Use CSM
    Mcdo2137 likes this.
  3. Mcdo2137
    Thank you, 2 layers of 3/4 Oz as all I have is 3/4 oz on hand?
  4. ondarvr
    I would probably use 2 layers only because 1 layer may not fully fill all the gaps between the two sheets of plywood. But if the plywood is very flat 1 might be sufficient.
  5. Mcdo2137
    20231008_201848.jpg Thanks, I went ahead and used 2 layers of 3/4 Oz csm for 1-1/2 Oz total.
    I got it all installed before evening hit. Pulled up with screws to exterior skin and straightened with a 2x6 from port to starboard.
    Thanks for your help!
    1. burke
    2. makobuilders
    3. Midday Gun
    4. ImaginaryNumber
    5. midcap
    6. FishStretcher
    7. DennisRB
    8. keith66
    9. SRQseaside
    10. mrdebian
