V8 Diesels, remove 2 and run on 6 cylinders
Discussion in 'Diesel Engines' started by markstrimaran, Sep 25, 2017.
  1. markstrimaran
    Likes: 6, Points: 28, Legacy Rep: 28
    markstrimaran Senior Member
    Seen this piston drop out on 12 cylinders big ship engines, know it will work on 6-71, Detroit. Easy with access panel.
    Thinking about a 6.5 Detroit, pull oil pan, loose two bad piston, with water damaged rings. Route injectors back to tank, pull push rods.
    Any ideas?
  2. Mr Efficiency
    A problem that comes to mind is the firing will be uneven around the 360*, presumably, will that increase vibrations ?
  3. markstrimaran
    I agree it will be out of balance a bit.
  4. markstrimaran
    I think it would work, and the engine would run a long time.
  5. Phil Christieso
    Likes: 4, Points: 18, Legacy Rep: 36
    Phil Christieso Junior Member
    Don't forget the hose clamps and strips of rubber around the crank shaft so as to maintain oil pressure. I have done this to an engine it ran for many hours.
    philSweet likes this.
  6. Lepke
    Likes: 6, Points: 8, Legacy Rep: 10
    Lepke Junior Member
    The engine will vibrate more. I would keep the rpms down and not long term. The crank isn't designed for imbalance. The missing cylinders are normally powering cycles in other cylinders.
    I did this on a 6 cylinder Enterprise. It ran with more vibration, but was only for a few hours. In Vietnam I ran a 671 for about a half hour that had taken a direct hit from an anti tank round. It didn't run good, but it got us home. Low air box pressure. Only did about 1000 rpm.
    markstrimaran likes this.
