urethane foam
Discussion in 'Fiberglass and Composite Boat Building' started by therigwelder, Jan 30, 2012.
  1. Herman
    Herman Senior Member
    I read it as the boat being 2000 lbs
  2. Gian Milan
    Gian Milan Previous Member
    my English is disgusting ...
    maybe I'm the one who did not understand
  3. therigwelder
    therigwelder Junior Member
    The boat is a 16 ft Trihull with an 85hp 1974 mercury.what. do I need to keep it afloat? Can I put boyancy on the sides versus under deck?
  4. Gian Milan
    can u post a picture?
  5. therigwelder
    I will try to take a pic.I could be wrong with 2000 lb weight.however the boat is 16 ft x4 ft 10 inx24 in sides
  6. Gian Milan
    try to take a pic
  7. therigwelder
    It originally had foam under deck and foam panels on the sides. I want to build a custom fishing boat.I need to know what I need for flotation
  8. Gian Milan
    Layout perfect if superior deck!
    u have to put bottles as high as possible.
    have plant of the boat u want to build?
  9. rasorinc
    rasorinc Senior Member
    You want to use rigid stryofoam. The floating docks use the blue stryofoam. When I put it under my dock 30 years ago it was brown in color. You can order it in any sizes and thickness or use standard dock billits and cut them yourself. It never absorbs water but needs to be protected from UV rays. 1 cubic foot floats 55 pounds. Does not rot and lasts forever.
  10. Gian Milan
    sure, blue stryofoam is ok. it is extruded polystyrene.
    Bottles cost less and are lighter.
    In Europe we have also square bottles, 1.5l.
    On my shallow water boat I put them.
  11. therigwelder
    I was only joking about using the bottles.I will put styrofoam planks in the side.will that suffice?I don't want to put flotation in the Hulll.my deck is already cut and laid on the stringers not screwed down Or glassed yet ,
  12. Gian Milan
    on my boat i've bottles.
    they're ok, believe me.
  13. alan white
    alan white Senior Member
    That is what I estimated. I said $20.00 worth which works out to 400 bottles at 5 cents return each. Fewer if you buy the bottles from a redemption center for 7 cents each. From about one kilogram each you get a total of 800-900 lbs positive flotation. Just about right for that weight/type of boat.
  14. alan white
    Use bottles (cheap, effective, available everywhere). They are SUPERIOR to foam, which is expensive and gets water-logged eventually unless you spend a lot of money, which you are welcome to do...). Water-logged foam is far worse than no flotation at all. Just because it's not a product you can buy from a marine supply is a poor excuse to avoid using it.
  15. Gian Milan
    Someone spoke of 2000 lbs? For the load?
    1. Vendy
    2. markstrimaran
    3. raslocum
    4. aaronhl
    5. BernieJ
    6. mrdebian
    7. bruceb
    8. catchcookcreate
    9. HG Faulkner
    10. fallguy
