unknown part
Discussion in 'Boat Design' started by Danob, Jan 9, 2016.
  1. Danob
    Danob Junior Member
    This item is in the mid Bilge of my Tollycraft 34. Can anyone tell me what it is and does?
    Thanks Danob
  2. JSL
    JSL Senior Member
    Could be a fume detector sensor? Any gasoline or LPG on board?
  3. PAR
  4. philSweet
    Likes: 565, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    I don't recognize that particular part, but it should be wired to either an alarm panel or wired so as to interrupt the ignition or gas supply of an appliance. CO and Combustible Vapor Detector is my guess based on the footprint. Either way, there should be a drop dead date on it, as well as a part number.
  5. Danob
    Danob Junior Member
    Thank You for the info. I was having some stalling issues and a Mechanic who worked on the Boat, said he thought it might be the sniffers in the engine room shutting down the Engine so he disconnected and removed them. I thought I saved the parts but can't find them. I've talked to several people about this and no one has heard of the sniffers that can detect fumes and shut the engine down?
    Has anyone heard of this and was it a wise idea to disconnect them?
    thanks
    Danob
  6. messabout
    Likes: 562, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    Safety devices should never be permanently disconnected.
  7. baeckmo
    Likes: 758, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    If you're running gas Engines it is wise to have the appropriate alarms functioning. If you ever saw the speed with which a gasoline fire is eating up a GRP hull, you wouldn't even ask the question.
