Tyvek 1443R
Discussion in 'Materials' started by flathead65, Mar 7, 2016.
  1. flathead65
    Likes: 1, Points: 8, Legacy Rep: 13
    flathead65 Junior Member
    Does anyone know where I can purchase Tyvek 1443R in western Canada/ U.S.?
    I phoned Dupont a couple of times and no luck. I want to make an experimental sail and need 100 ft roll x60". 1443R is the soft material unlike house wrap which is paper like. Thanks.
  2. rasorinc
    rasorinc Senior Member
    I would think any lumber store that sells building materials and tyvek could order a full roll of what you want. Start calling some.
  3. PAR
    Likes: 485, Points: 93, Legacy Rep: 3967
    Check with (> http://intothewind.com/ <) and other kit and back back makers.
    There are a number of version of Tyvek and I'd recommend you use 3M -300LSE as the adhesive or Tyvek tape, which is available at the big box stores.
    1443R is pretty soft and light, just over a ounce per yard. You can get a fair soft Tyvek if you use the 1020 style, which is 2 and a little over ounces per. Just toss in in the washing machine and run 3 or 4 "delicate" cycles. It'll come out soft and much more fabric like, without all the noise of the type 10 versions.
    Here's a few links for an actual roll of the stuff.
    http://www.materialconcepts.com/store/categories/0200
