OneWayTraffic
Junior Member
- Joined
- Jun 15, 2018
- Messages
- 20
- Reaction score
- Location
- South Island, NZ
I have built my first project, a Bateau D5. Although happy with the outcome and performance of the boat relative to the size, materials and effort I put into her, I would like to drastically reduce her tendency to tip, while at the same time adding level flotation. The boat currently has a rear compartment with a hatch and enough pool noodles in both that and under the middle seat to float the boat alone.
Pictures and details of the build can be found here:
Stuart's D5 Dinghy. - Bateau2 - Builder Forums https://forums.bateau2.com/viewtopic.php?f=14&t=62403
At the moment I have been thinking over the following commercial options:
Airofloat stabilizers. At least $700 NZD including postage and fitting.
Kapten boat collars. I got a quote of $900 AUD including postage to NZ (posting foam isn't cheap.)
I also considered fenders etc on the outside but want a slighter better look.
I have thought about an outrigger, but would like an integrated option preferably.
The main DIY option I am currently looking at is to buy some polyurethane foam sheet, which I can locally buy in densities of 34,65 and 96 kg a m3, and then epoxy glue this in layers to the hull sides and glass over. I have a roll of 400g biaxial tape and would use West System 105. I could easily build up a good 20cm by 15cm by 2m for about 60 litres buoyancy a side. What I am not sure about is whether this last option would hold up to wear, tear and damage.
Of the above densities of foam, which would be the best option to use, and will a layer of 400g biaxial be sufficient to protect against bumps and impacts?
